Dell Wyse 5010 Thin Client G-T48E 1.40 GHz DC 2GB 8GB Suse Linux
Quicklinx: C5S8WS00 Mfr#: FV6F4
Thin client for virtual desktop environments also serves as a powerful yet compact cloud desktop.
  • Strong and compact
    The Wyse 5000 series thin client is a highly-efficient and powerful endpoint platform for virtual desktop environments. With its extremely compact size and high performance, it's a versatile virtual desktop endpoint.
  • High-performance multimedia
    Need to deploy a dependable platform to display, manipulate and work with high-definition multimedia, voice and video in a virtualized environment? The 5000 series thin client delivers stunning performance and display capabilities across 2D, 3D and HD video applications. As such, it supports a broad and diverse range of user, application and operating requirements.
  • Highly scalable, easy to operate and manage
    IT administrators won't need to visit or touch cloud clients to manage them. The 5000 series thin client can be managed remotely that lowers the total cost of ownership for large deployments and offers remote enterprise-wide management that scales as you grow from just a few to tens of thousands of cloud clients.
  • Environmentally conscious computing without compromise
    The silent diskless and fanless design helps reduce power usage. Dell is committed to helping you implement a computing strategy with a lower environmental impact that offers an efficient and productive computing experience by significantly reducing energy usage and heat generation.
Dell Wyse 5010 - DTS - G-T48E 1.4 GHz - 2 GB - flash 8 GB
Thin client - desktop slimline
Bundled Services
3 Years Dell Collect and Return Service
1 x AMD G-T48E 1.4 GHz (Dual-Core)
RAM
2 GB (installed) / 4 GB (max) - DDR3 SDRAM
Hard Drive
Flash 8 GB
Optical Storage
No optical drive
Graphics Controller
AMD Radeon HD 6250
Audio Output
Stereo
GigE
OS Provided
Wyse Enhanced SUSE Linux
4 cm x 18.5 cm x 17 cm
930 g
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years
Thin client
Bundled Services
Product Form Factor
Desktop slimline
Built-in Devices
Speaker
Processor / Chipset
CPU
AMD G-T48E
Clock Speed
1.4 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
2 GB / 4 GB (max)
DDR3 SDRAM
Effective Memory Speed
1066 MHz
Hard Drive
Flash
1 x 8 GB / max 8 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon HD 6250
Video Interfaces
DVI, DisplayPort
Audio Output
Sound Output Mode
Stereo
Input Device
Mouse (on selected markets only)
Mouse
Optical
USB
1 x DVI-I , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone , 1 x DisplayPort
Vertical stand
DVI-VGA adapter
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Pricing Type
Power adapter
Power Provided
65 Watt
8 Watt
Operating System / Software
OS Provided
Sustainability Information
ENERGY STAR Certified
4 cm
18.5 cm
17 cm
930 g
10 °C
10 - 95% (non-condensing)
C5S8 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
C5S8 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.43
