Dell Wyse 3012-T10D Thin Client DTS 2GB
Quicklinx: BJ43WS00 Mfr#: 909641-02L
Empower your team with enterprise-class thin clients on an entry-level budget. These thin clients feature a wealth of premium Wyse cloud client features and are ready to connect to almost any environment, including web-based applications and services.
A built-in hardware media processor helps deliver smooth imagery, bi-directional audio and flash playback performance. Moreover, the 3012-T10D offers even greater functionality with support for up to two digital displays and Microsoft RemoteFX certification for high-end graphics.
Designed for cost-effective virtual desktop deployments, these thin clients deliver great value from day one with minimal initial investment and power-efficient operation that help lower your cost of ownership.
Dell Wyse 3012-T10D - DTS - ARMADA PXA2128 1.2 GHz - 2 GB - flash 4 GB
Thin client - desktop slimline
1 x Marvell ARMADA PXA2128 / 1.2 GHz (Dual-Core)
RAM
2 GB DDR3 SDRAM
Hard Drive
Flash 4 GB
Optical Storage
No optical drive
Audio Output
Stereo - integrated
GigE
OS Provided
Wyse Thin OS
17.6 cm x 12.1 cm x 3.5 cm
500 g
Limited warranty - 3 years
Thin client
Product Form Factor
Desktop slimline
Processor / Chipset
CPU
Clock Speed
1.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
2 GB
DDR3 SDRAM
Hard Drive
Flash
4 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
DVI
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
48 kHz
Integrated
1 x DVI-I , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-out , 1 x DVI-D
Horizontal feet
DVI-VGA adapter
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
Power adapter
Operating System / Software
OS Provided
Wyse Thin OS
17.6 cm
12.1 cm
3.5 cm
500 g
10 °C
35 °C
10 - 95% (non-condensing)
BJ43 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
BJ43 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
