Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey
Quicklinx: GHJ5WS00 Mfr#: KM7120W-GY-UK
Recommended Use: Leisure
Type: Mouse, Keyboard
Wired / Wireless: Wireless
Colour: Titan grey
Compatibility: PC
More than 50 In Stock
£41.60 ex VAT
£49.92 inc VAT
Dell Multi-Device Wireless Keyboard and Mouse - KM7120W - UK (QWERTY).
  • Conveniently switch
    Seamlessly connect to three PCs. The two Bluetooth 5.0 and 2.4 GHz wireless connection methods allow you to switch easily across your laptop, desktop or 2-in-1 with a click of a button.
  • Built to last
    With many months of battery life, you do not have to be concerned with frequent battery replacements.
  • Precise tracking
    Rapid responses via the 1600 dpi sensor helps you navigate effortlessly, especially across your high-resolution 4K screen. Its optical sensor offers accurate tracking and is ideal for use on most desk surfaces.
  • Easy customization
    Tilt the keyboard to your desired angle to type comfortably. Program shortcuts for your keyboard and mouse for quick navigation to your preferred applications. The intuitive positioning makes them easy to access every time.
Dell Pro Plus Compact Keyboard and Mouse - KM7120W - keyboard and mouse set - UK - titan grey Input Device
Keyboard and mouse set
2.4 GHz, Bluetooth 5.0
Wireless
Localization and Layout
Hot Keys Function
Multimedia, search, home page, volume -, volume +, print screen
Pointing Device
Mouse - wireless - optical
Buttons Qty
7
Titan grey
Bundled Services
3 years NBD Advance Exchange
Dimensions (WxDxH) / Weight
Keyboard: 36.3 cm x 12.2 cm x 2.54 cm / 510 g , Mouse: 6.86 cm x 11.4 cm x 4.06 cm / 85 g
Bundled Services
Wireless
Hot Keys Function
Keyboard Technology
Scissors
Pointing Device
Mouse - wireless
Buttons Qty
7
Movement Detection Technology
Optical
Movement Resolution
1600 dpi
Titan grey
3 AA batteries
Apple MacOS, Microsoft Windows 7, Android, Ubuntu, Google Chrome OS, Windows 8, Windows 8.1, Windows 10
Type: Mouse
Type: Keyboard
Colour: Titan grey
Compatibility: PC
Brand: Dell
