Conveniently switch
Seamlessly connect to three PCs. The two Bluetooth 5.0 and 2.4 GHz wireless connection methods allow you to switch easily across your laptop, desktop or 2-in-1 with a click of a button. -
Built to last
With many months of battery life, you do not have to be concerned with frequent battery replacements. -
Precise tracking
Rapid responses via the 1600 dpi sensor helps you navigate effortlessly, especially across your high-resolution 4K screen. Its optical sensor offers accurate tracking and is ideal for use on most desk surfaces. -
Easy customization
Tilt the keyboard to your desired angle to type comfortably. Program shortcuts for your keyboard and mouse for quick navigation to your preferred applications. The intuitive positioning makes them easy to access every time.
- Dell Multi-Device KM7120W - keyboard and mouse set - UK - titan grey
- Keyboard and mouse set
- Interface
- 2.4 GHz, Bluetooth 5.0
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Hot Keys Function
- Multimedia, search, home page, volume -, volume +, print screen
- Pointing Device
- Mouse - wireless - optical
- Buttons Qty
- 7
- Titan grey
- 3-year warranty
- Designed For
- Latitude 3310 2-in-1; Precision 5750, 7750; XPS 15 9510
- Interface
- Dimensions (WxDxH) / Weight
- Keyboard: 36.3 cm x 12.2 cm x 2.54 cm / 510 g , Mouse: 6.86 cm x 11.4 cm x 4.06 cm / 85 g
Input Device
- Wireless
- Hot Keys Function
- UK
- Keyboard Technology
- Scissors
Pointing Device
- Mouse - wireless
- Buttons Qty
- 7
- Movement Detection Technology
- Optical
- Movement Resolution
- 1600 dpi
- Titan grey
- Included Accessories
- 3 AA batteries
- OS Required
- Apple MacOS, Microsoft Windows 7, Android, Ubuntu, Google Chrome OS, Windows 8, Windows 8.1, Windows 10
- Advanced Exchange Service - 3 years
- Designed For
- Dell Latitude 3310 2-in-1 , Dell Precision 5750, 7750 , Dell XPS 15 9510
