Dell Wireless Dock - UK
Quicklinx: BD56WS00 Mfr#: 452-BBUV
The Dell wireless dock provides seamless high-speed wireless docking to your network through Intel WiGig technology powering up to two external displays, keyboard, mouse, audio and other peripherals.
Simply connect all the devices and peripherals you use every day to the Dell wireless dock and your laptop will communicate wirelessly with the dock. With two USB ports in front and three USB ports in back, the dock unites everything conveniently in one place for your wireless desktop.
Work more efficiently and increase productivity with two external displays and all the devices on your desktop. The Dell wireless dock supports VGA, HDMI and mDP for up to two displays.
  • Seamless wireless docking
  • Convenient connections
  • Increase at the desk productivity
  • WiGig high speed
    Using Intel WiGig technology, the Dell wireless dock enables higher data transfer rates up to 4.6 Ghz - higher than Wifi AC certified products.
  • Secure communication
    Work confidently knowing your files are protected with data encryption and strong authentication protocols IEEE802.11 and current WLAN technologies.
  • Easy presentation connectivity
    Simplify access to presentation and collaboration tools in your meeting rooms and classrooms with fast, reliable connectivity to projectors and other compatible equipment.
Dell WLD15 - wireless docking station - VGA, HDMI, Mini DP - GigE, 802.11ad (WiGig)
Wireless docking station
Video Interfaces
VGA, HDMI, Mini DP
12 cm x 12 cm x 7 cm
363.42 g
Gigabit Ethernet, IEEE 802.11ad (WiGig)
Power adapter AC 120/230 V (50/60 Hz) 65 Watt Power Provided
Latitude 13 7350, 3550, 5480, 7370, E5250, E5270, E5450, E5470, E5550, E7250, E7270, E7450
12 cm
12 cm
7 cm
363.42 g
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ad (WiGig)
IEEE 802.11ad
1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x display / video - Mini DisplayPort , 1 x audio / video - HDMI - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - RJ-45 , 1 x audio - headphones/microphone , 1 x audio - line-out/headphones
Security lock slot (cable lock sold separately), LED indicator, reset switch, USB PowerShare technology, dual display support
Security Slot Type
Kensington security slot
Power adapter
Power Provided
65 Watt
Microsoft Windows 7 / 8 / 8.1 / 10
35 °C
Dell Latitude 13 7350, 3550, 5480, 7370, E5250, E5270, E5450, E5470, E5550, E7250, E7270, E7450
