The Dell wireless dock provides seamless high-speed wireless docking to your network through Intel WiGig technology powering up to two external displays, keyboard, mouse, audio and other peripherals.
Simply connect all the devices and peripherals you use every day to the Dell wireless dock and your laptop will communicate wirelessly with the dock. With two USB ports in front and three USB ports in back, the dock unites everything conveniently in one place for your wireless desktop.
Work more efficiently and increase productivity with two external displays and all the devices on your desktop. The Dell wireless dock supports VGA, HDMI and mDP for up to two displays.
Seamless wireless docking
The Dell wireless dock provides seamless high-speed wireless docking to your network through Intel WiGig technology powering up to two external displays, keyboard, mouse, audio and other peripherals. -
Convenient connections
Simply connect all the devices and peripherals you use every day to the Dell wireless dock and your laptop will communicate wirelessly with the dock. With two USB ports in front and three USB ports in back, the dock unites everything conveniently in one place for your wireless desktop. -
Increase at the desk productivity
Work more efficiently and increase productivity with two external displays and all the devices on your desktop. The Dell wireless dock supports VGA, HDMI and mDP for up to two displays. -
WiGig high speed
Using Intel WiGig technology, the Dell wireless dock enables higher data transfer rates up to 4.6 Ghz - higher than Wifi AC certified products. -
Secure communication
Work confidently knowing your files are protected with data encryption and strong authentication protocols IEEE802.11 and current WLAN technologies. -
Easy presentation connectivity
Simplify access to presentation and collaboration tools in your meeting rooms and classrooms with fast, reliable connectivity to projectors and other compatible equipment.
- Dell WLD15 - wireless docking station - VGA, HDMI, Mini DP - GigE, 802.11ad (WiGig)
- Product Type
- Wireless docking station
- Video Interfaces
- 12 cm x 12 cm x 7 cm
- 363.42 g
- Networking
- Gigabit Ethernet, IEEE 802.11ad (WiGig)
- Power
- Power adapter AC 120/230 V (50/60 Hz) 65 Watt Power Provided
- Designed For
- Latitude 13 7350, 3550, 5480, 7370, E5250, E5270, E5450, E5470, E5550, E7250, E7270, E7450
- Product Type
- 12 cm
- 12 cm
- 7 cm
- 363.42 g
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ad (WiGig)
- IEEE 802.11ad
- 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x display / video - Mini DisplayPort , 1 x audio / video - HDMI - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - RJ-45 , 1 x audio - headphones/microphone , 1 x audio - line-out/headphones
- Security lock slot (cable lock sold separately), LED indicator, reset switch, USB PowerShare technology, dual display support
- Security Slot Type
- Kensington security slot
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Provided
- 65 Watt
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- 0 °C
- 35 °C
- Designed For
- Dell Latitude 13 7350, 3550, 5480, 7370, E5250, E5270, E5450, E5470, E5550, E7250, E7270, E7450
