Dell Wireless Card
Dell Wireless Card
Quicklinx: 8B3SWS00 Mfr#: 556-11120
Stay connected while on the go with the Wireless 5550 3G/HSDPA mobile broadband card from Dell. It helps maximize your productivity while maintaining contact with clients, colleagues and family. Its high efficiency compact broadband design provides consistent throughput performance. Its GPS capability allows you to retrieve location data from GPS satellites, utilize GPS navigation and location-based applications.
Dell Wireless 5550 - wireless cellular modem - 3G
Wireless cellular modem - PCIe Mini Card
Internal
Mobile Communication Protocol
GSM, GPRS, EDGE, HSDPA, WCDMA, HSUPA, HSPA+
Microsoft Windows XP SP2, Microsoft Windows Vista (32/64 bits), Ubuntu, Microsoft Windows 7 (32/64 bits)
Latitude 2120, E5420, E5420 N-Series, E5520, E5520 BRC 6, E5520 N-Series, E6220, E6320, E6320 N-Series, E6420, E6420 N-Series, E6520, E6520 N-Series
Internal
Built-in Devices
GPS
Modem
Bus
PCIe Mini Card
Wireless
Assisted GPS
Compatible Slots
1 x PCI Express Mini Card
RoHS
Dell Latitude 2120, E5420, E5420 N-Series, E5520, E5520 BRC 6, E5520 N-Series, E6220, E6320, E6320 N-Series, E6420, E6420 N-Series, E6520, E6520 N-Series
