Stay connected while on the go with the Wireless 5550 3G/HSDPA mobile broadband card from Dell. It helps maximize your productivity while maintaining contact with clients, colleagues and family. Its high efficiency compact broadband design provides consistent throughput performance. Its GPS capability allows you to retrieve location data from GPS satellites, utilize GPS navigation and location-based applications.
- Dell Wireless 5550 - wireless cellular modem - 3G
- Wireless cellular modem - PCIe Mini Card
- Form Factor
- Internal
- Mobile Communication Protocol
- GSM, GPRS, EDGE, HSDPA, WCDMA, HSUPA, HSPA+
- System Requirements
- Microsoft Windows XP SP2, Microsoft Windows Vista (32/64 bits), Ubuntu, Microsoft Windows 7 (32/64 bits)
- Designed For
- Latitude 2120, E5420, E5420 N-Series, E5520, E5520 BRC 6, E5520 N-Series, E6220, E6320, E6320 N-Series, E6420, E6420 N-Series, E6520, E6520 N-Series
- Form Factor
- Internal
- Built-in Devices
- GPS
Modem
- Bus
- PCIe Mini Card
- Connectivity Technology
- Wireless
- Assisted GPS
- Compatible Slots
- 1 x PCI Express Mini Card
- RoHS
- OS Required
- Designed For
- Dell Latitude 2120, E5420, E5420 N-Series, E5520, E5520 BRC 6, E5520 N-Series, E6220, E6320, E6320 N-Series, E6420, E6420 N-Series, E6520, E6520 N-Series
