Dell WEBCAM - WB3023
Quicklinx: HC2XWS00 Mfr#: WB3023-DEMEA
More than 50 In Stock
£51.99 ex VAT
£62.38 inc VAT
Collaborate confidently with this 2K QHD webcam that's essential for everyday use.
  • Picture perfect
    Experience vivid picture clarity through this 2K QHD, 1440p camera with a Sony image sensor.
  • Authentically you
    Experience true-to-life color with High Dynamic Range (HDR) in most lighting situations. See facial features clearly with Facial Detection Auto Exposure (FDAE) that evens out harsh lighting. Enjoy image clarity even in low light with Temporal (3D) and Spatial (2D) Noise Reduction that eliminates graininess and motion blur.
  • Make your voice heard
    Communicate clearly no matter what's going on around you with the built-in noise reduction mic.
  • Adjust your view
    Protect your privacy with the integrated sliding privacy shutter for when the webcam is not in use. Manage how much of your surroundings are included in frame with the swivel and tilt features as well as adjustable Field of View (65°, 78°).
Dell WB3023 - webcam
Webcam - fixed
Audio
Yes: built-in microphone
4.8 cm x 6.9 cm x 8.9 cm
151 g
Wired
Camera
Max Resolution
2560 x 1440
Frame Rate (max)
60 frames per second
Lens Iris
F/2.0
USB 2.0
Software Certification
Zoom Certified, Certified for Microsoft Teams
1 - USB cable - 1.5 m
2D Noise Reduction Technology, 3D Noise Reduction Technology, face detection, tilt adjustment, High Dynamic Range (HDR), auto white balance, Auto Focus, 78° field of view, 65° field of view, integrated privacy shutter, tripod support, Sony sensor
3-year warranty
Webcam
Audio Support
Wired
4.8 cm
6.9 cm
8.9 cm
151 g
Camera
Colour - fixed
Max Digital Video Resolution
2560 x 1440
Digital Zoom
2
Video Capture
2560 x 1440 @ 24 fps , 2560 x 1440 @ 30 fps , 1920 x 1080 @ 24 fps , 1920 x 1080 @ 30 fps , 1280 x 720 @ 24 fps , 1280 x 720 @ 30 fps , 1280 x 720 @ 60 fps
Lens Construction
Lens Iris
F/2.0
Computer Interface
USB 2.0
Ports
USB 2.0
1 x USB cable - 1.5 m
Software Included
Dell Peripheral Manager
Apple MacOS, Windows 10 64-bit Edition, Windows 11
Limited warranty - 3 years
