Picture perfect
Experience vivid picture clarity through this 2K QHD, 1440p camera with a Sony image sensor. -
Authentically you
Experience true-to-life color with High Dynamic Range (HDR) in most lighting situations. See facial features clearly with Facial Detection Auto Exposure (FDAE) that evens out harsh lighting. Enjoy image clarity even in low light with Temporal (3D) and Spatial (2D) Noise Reduction that eliminates graininess and motion blur. -
Make your voice heard
Communicate clearly no matter what's going on around you with the built-in noise reduction mic. -
Adjust your view
Protect your privacy with the integrated sliding privacy shutter for when the webcam is not in use. Manage how much of your surroundings are included in frame with the swivel and tilt features as well as adjustable Field of View (65°, 78°).
- Dell WB3023 - webcam
- Webcam - fixed
- Audio
- Yes: built-in microphone
- 4.8 cm x 6.9 cm x 8.9 cm
- 151 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 2560 x 1440
- Frame Rate (max)
- 60 frames per second
- Lens Iris
- F/2.0
- USB 2.0
- Software Certification
- Zoom Certified, Certified for Microsoft Teams
- Cables Included
- 1 - USB cable - 1.5 m
- 2D Noise Reduction Technology, 3D Noise Reduction Technology, face detection, tilt adjustment, High Dynamic Range (HDR), auto white balance, Auto Focus, 78° field of view, 65° field of view, integrated privacy shutter, tripod support, Sony sensor
- 3-year warranty
- Webcam
- Audio Support
- Wired
- 4.8 cm
- 6.9 cm
- 8.9 cm
- 151 g
Camera
- Colour - fixed
- Max Digital Video Resolution
- 2560 x 1440
- Digital Zoom
- 2
- Video Capture
- 2560 x 1440 @ 24 fps , 2560 x 1440 @ 30 fps , 1920 x 1080 @ 24 fps , 1920 x 1080 @ 30 fps , 1280 x 720 @ 24 fps , 1280 x 720 @ 30 fps , 1280 x 720 @ 60 fps
Lens Construction
- Lens Iris
- F/2.0
- Computer Interface
- USB 2.0
- Ports
- USB 2.0
- Cables Included
- 1 x USB cable - 1.5 m
- Software Included
- Dell Peripheral Manager
- OS Required
- Apple MacOS, Windows 10 64-bit Edition, Windows 11
- Limited warranty - 3 years
