Dell Vostro 5510 Intel Core i5-11320 8G 256G 15.6" W10P
Quicklinx: GWLMWS00 Mfr#: 6GJFJ
  • Core i5
  • IEEE 802.11n
Vostro 5510|i5-11320H|8GB|256GB SSD|15.6" FHD|Intel Iris Xe|FgrPr|4 Cell|65W|WLAN|Backlit Kb|W10Pro+W11Pro Licence|1Y Coll&Rtn.
  • Powerful processing
    Tackle your to-do list and power through your workday with performance you can rely on thanks to the advanced processor.
  • Keeps its cool
    A redesigned thermal system unleashes the power of your device, while also preserving its thin design. Dual heat pipes move heat away from your CPU and GPU, more fan blades move more air, and a drop-hinge allows air to circulate underneath your laptop.
  • Peace and quiet
    With a fluid dynamic bearing system, your laptop's fan is not only long-lasting, but it also runs quietly while keeping your device performing at its best.
  • Work where you want
    Enjoy optimal connectivity with Wi-Fi 6 which means faster downloads, smoother streaming and easier sharing.
  • Narrow borders
    With its 4-sided narrow border, the Vostro 5510 has more screen space for multitasking so you can minimize distractions and maximize your productivity.
  • Size is the key
    The spill-resistant keyboard with larger pitch keys gives users added typing comfort so you stay productive.
  • Crystal-clear camera
    The high-quality HD camera lets you converse face to face in vivid detail, and its size allows for borders to be narrower.
  • Waves MaxxAudio
    Never miss a word with an immersive audio experience professionally tuned by Waves MaxxAudio Pro that includes echo cancellation and background noise reduction. When you're conferencing, you're not disrupted by hearing your own voice, and sound is clean and clear.
Dell Vostro 15 5510 - 15.6" - Intel Core i5 - 11320H - 8 GB RAM - 256 GB SSD - English
Notebook
Operating System
Win 10 Pro 64-bit + Windows 11 Pro Licence - Multilingual User Interface (MUI)
Intel Core i5 (11th Gen) - 11320H up to 4.5 GHz / 8 MB Cache
8 GB DDR4
Storage
256 GB SSD - NVMe
Display
15.6" LED backlight 1920 x 1080 / Full HD @ 60 Hz - 141 ppi
Graphics
Intel Iris Xe Graphics
Keyboard
English
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Grey
35.606 cm x 22.882 cm x 1.799 cm
1.64 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Dell Collect and Return Service
Notebook
Operating System
Windows 10 Pro 64-bit Edition + Windows 11 Pro Licence - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core i5 (11th Gen) 11320H
Max Turbo Speed
4.5 GHz
Number of Cores
Quad-Core
Cache
8 MB
Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
3200 MHz
Rated Speed
3200 MHz
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
141
Image Aspect Ratio
16:9
Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, Narrow Border Display, 35 ms response rate, 0.179 mm pixel pitch
Audio & Video
Graphics Processor
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Privacy shutter, Windows Hello, 74.9 degrees, RGB camera
Sound
Stereo speakers, dual array microphone
High Definition Audio
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
English
Numeric Keypad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201 - M.2 2230
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111H-CG
4-cell lithium polymer
54 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Interfaces Details
HDMI , 2 x USB 3.2 Gen 1 , USB-C 3.2 Gen 2x2 (Power Delivery) , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Microsoft Office (30 days trial), McAfee Small Business Security (12 months subscription)
Grey
Security
ExpressCharge, SmartByte technology
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
WEEE, CEL, China RoHS, EU RoHS
Pricing Type
1.64 kg
Sustainability Information
TCO Certified
Bundled Services
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
GWLM Dell 1Y Coll&Rtn to 3Y Basic Onsite In Stock £113.56
Other bundles (6)
GWLM Dell Slim DW316 USB External DVD Drive In Stock £40.60
GWLM Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £25.61
GWLM Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £44.32
GWLM Dell SB521A Magnetic Sound bar In Stock £30.78
GWLM Dell MS5120W Mobile Pro Wireless Mouse In Stock £28.14
GWLM Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £43.18
