Dell Vostro 5501 Intel Core i5-1035G1 8GB 256GB 15.6" W10P
Quicklinx: FZBKWS00 Mfr#: 0TD62
  • Core i5
  • IEEE 802.11n
For workers on the move, the Vostro 15 5000 offers a durable design that passes 14 different military-grade tests to ensure your laptop withstands real-world conditions as you work on the go.
A sleek aluminum finish gives the Vostro 15 5000 a premium, stylish look all its own. A brilliant FHD panel (up to 300 nits) offers more brightness and vivid color for an enhanced front-of-screen experience. The Vostro 15 5000 can automatically detect where it's placed. This allows it to intelligently adapt its thermal profiles to stay cool if it's in your lap or hands, and work at full power when stationary on a desk.
  • Built to last
  • Work in style
  • Powerful processing
    Tackle your workday with the power of up to 10th Gen Intel Core processors.
  • Narrow borders
    A 3-sided narrow border maximizes the surface area of the 15-inch screen, while helping minimize distractions.
  • Dazzling display
  • Intelligent thermals
  • Redesigned hinge
    The new drop hinge lifts the laptop slightly off the table when open past a 135-degree angle, allowing for improved air circulation and a more comfortable typing experience.
  • Numeric keypad
    Calculations are a snap with a dedicated numeric keypad.
Dell Vostro 5501 - 15.6" - Intel Core i5 - 1035G1 - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (10th Gen) - 1035G1 / 1 GHz, up to 3.6 GHz / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe
Display
15.6" LED backlight 1920 x 1080 / Full HD @ 60 Hz - 142 ppi
Graphics
Intel UHD Graphics
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Grey
35.61 cm x 23.45 cm x 1.79 cm
1.7 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Dell Collect and Return Service
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core i5 (10th Gen) 1035G1 / 1 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
3200 MHz
Rated Speed
3200 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
142
Image Aspect Ratio
16:9
Anti-glare, Wide Viewing Angle, ±85° horizontal viewing angle, ±85° vertical viewing angle, 0.18 mm pixel pitch
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Privacy shutter, 74.9 degrees, RGB camera
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Communications
Wireless
Wireless Controller
Dell Wireless 1820
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111
3-cell Lithium Ion
40 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V, 2.31 A
Connections & Expansion
Interfaces Details
HDMI , 2 x USB 3.2 Gen 1 , USB-C 3.2 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft Office (Trial), McAfee (12 months subscription), Dell Mobile Connect
Grey
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.7 kg
Sustainability Information
TCO Certified
Bundled Services
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms
Shock Tolerance (non-operating)
160 g @ 2 ms
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
