14" thin, lightweight laptop with premium, colorful design and powerful performance for professionals seeking impressive style and mobility.
Travel in style
Built to go easily wherever business takes you. The thin, lightweight design allows for maximum mobility, while the stylish aluminum casing and palm rest combine durability with a look of sleek professionalism. -
Exceptional clarity
The anti-glare IPS display ensures sharp, detailed visuals from every angle for convenient group collaboration, while the built-in HD webcam and Waves MaxxAudio Pro allow you to collaborate remotely with crisp video and audio clarity. -
Robust connectivity
A wide array of ports including USB 3.1 Gen 1 Type-A (x2), USB 3.1 Gen 1 Type-C (x1), HDMI and SD card reader allow you stay connected to a variety of devices. -
Manageability you can count on
Easy access to Dell BIOS offers broad manageability to configure your system to your specifications. -
Accident protection
A free-fall sensor locks the hard drive and prevents data from being lost or damaged if your laptop is shaken or dropped.
- Dell Vostro 5471 - 14" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 3-cell
- Silver
- 34.3 cm x 24.08 cm x 1.74 cm
- 1.685 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 1 year
- Bundled Services
- 1 Year Dell Collect and Return Service
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Camera Features
- Fixed focus
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3254-CG
- High Definition Audio
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165
- Network Interface
- Gigabit Ethernet
- Technology
- 3-cell
- Capacity
- 42 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V, 2.31 A
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , USB-C 3.1 Gen 1 , HDMI , Headphone/microphone combo jack , LAN
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Silver
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.685 kg
Sustainability Information
- TCO Certified
- Bundled Services
- 0 °C
- 35 °C
- 20 - 80% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms
- Shock Tolerance (non-operating)
- 105 g @ 2 ms
- Vibration Tolerance (operating)
- 5-350 Hz
- Vibration Tolerance (non-operating)
- 5-500 Hz
