Dell Vostro 5415 AMD Ryzen 5 5500U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: GFX4WS00 Mfr#: W4VMD
  • IEEE 802.11n
14-inch laptop with a sleek, reliable design, advanced security features, upgradeability options, 4-sided narrow borders and AMD Ryzen processor.
  • Work in style
    A sleek aluminum finish gives the Vostro 5415 a professional look, so you'll put your best foot forward no matter where your work takes you.
  • Powerful processing
    Power through your workday with the AMD Ryzen processor with Radeon graphics, which deliver a performance you can rely on as you accomplish your business goals.
  • Size is key
    A spill-resistant keyboard with larger pitch keys give users added typing comfort so you can stay productive.
  • Keeps its cool
    A redesigned thermal system unleashes the power of your device, while also preserving its thin design. Dual heat pipes move heat away from your CPU and GPU, more fan blades move more air, and a drop-hinge allows air to circulate underneath your laptop.
  • Peace and quiet
    With a fluid dynamic bearing system, your laptop's fan is not only long-lasting, but it also runs quietly while keeping your device performing at its best.
  • Narrow borders
    Minimize distractions and get more done with a 4-sided narrow border that maximizes the surface area of the 14-inch screen so you can focus better on the tasks at hand.
  • Charge up
    Charge your device up to 80% in an hour with ExpressCharge for worry-free battery performance that won't keep you tethered to an outlet.
  • Prioritize privacy
    The privacy shutter ensures no one can see you while the HD webcam isn't in use, so you're protected from accidental embarrassments.
  • TPM 2.0
    The Trusted Platform Module 2.0 is a commercial-grade security chip installed on the motherboard that creates and stores passwords and encryption keys. It verifies that the computer has not been tampered with before booting up and protects your data against external software attacks.
Dell Vostro 5415 - 14" - AMD Ryzen 5 - 5500U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
AMD Ryzen 5 5500U / 2.1 GHz, up to 4 GHz / 8 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe
Display
14" LED backlight 1920 x 1080 / Full HD @ 60 Hz - 157 ppi
Graphics
AMD Radeon Graphics
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
4-cell
Security
Fingerprint reader
Grey
32.127 cm x 21.28 cm x 1.799 cm
1.44 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Dell Collect and Return Service
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
6-core
Cache
L3 - 8 MB
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
3200 MHz
Rated Speed
3200 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe 3.0 x4 - NVM Express (NVMe)
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
157
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, 35 ms response rate, 0.161 mm pixel pitch
Audio & Video
Graphics Processor
AMD Radeon Graphics - up to
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Privacy shutter, 74.9 degrees, RGB camera
Sound
Stereo speakers, dual array microphone
High Definition Audio
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Dell Wireless 1820 - M.2 2230
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111H-CG
4-cell lithium polymer
54 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Interfaces Details
HDMI , 2 x USB 3.2 Gen 1 , USB-C 3.2 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial), Dell Mobile Connect
Grey
Security
Fingerprint reader
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.44 kg
Sustainability Information
TCO Certified
Bundled Services
10 - 90% (non-condensing)
Shock Tolerance (operating)
140 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
GFX4 Dell 1Y Coll&Rtn to 3Y Basic Onsite In Stock £113.56
Other bundles (6)
GFX4 Dell Slim DW316 USB External DVD Drive In Stock £35.33
GFX4 Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.60
GFX4 Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £45.03
GFX4 Dell SB521A Magnetic Sound bar In Stock £35.11
GFX4 Dell MS5120W Mobile Pro Wireless Mouse In Stock £25.91
GFX4 Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £45.19
