Dell Vostro 3515 AMD Ryzen 5 3450U 8GB 256GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: GM1YWS00 Mfr#: 4MKV2
  • IEEE 802.11n
Featuring an advanced processor, this laptop gives you the essentials you need to keep your small business productive and secure.
  • Powerful performance
    Everyday tasks are quickly handled with ease using powerful processors.
  • A battery that lasts
    With a powerful battery, you know you can rely on your device to power through the day.
  • Recharge in a flash
    Untether from the wall and get worry free power on-the-go with a charge in one hour using Express Charge.
  • Making productivity a priority
    A 3-sided narrow border makes for a more immersive front of screen experience so you can focus more on the work at hand.
  • Increase your comfort
    A large touchpad, bigger keycaps and a lift hinge for more ergonomic wrist angles - all make for a more relaxed use. Plus, the lift hinge provides increased air flow, so your device stays cooler.
  • Efficient tools
    Get work done faster with a 10-key numeric pad and a calculator key that populates a calculator with just one touch.
  • Low blue light
    Dell ComfortView software technology reduces harmful blue light emissions to make extended screen time easy on your eyes.
  • No need for spilling tears
    A spill-resistant keyboard means less stress if an accident happens.
  • Hardware TPM 2.0
    The Trusted Platform Module 2.0 is an advanced security chip installed on the motherboard that creates and stores passwords and encryption keys. It verifies that the computer has not been tampered with before booting up and protects your data against external software attacks.
  • Transfer files seamlessly
    Transfer files, photos, videos, music, and documents between your PC and phone without complicated cloud storage or cumbersome cables.
  • Maintain your privacy
    Your phone connects to your PC via Dell Mobile Connect's point-to-point secure connection so your data is never exposed via insecure Internet connections.
Dell Vostro 15 3515 - 15.6" - AMD Ryzen 5 - 3450U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
AMD Ryzen 5 3450U / 2.1 GHz, up to 3.5 GHz / 4 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe
Display
15.6" 1920 x 1080 / Full HD @ 60 Hz - 141 ppi
Graphics
AMD Radeon Vega 8
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
3-cell
35.85 cm x 23.556 cm x 1.75 cm
1.7 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Dell Collect and Return Service
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
L3 - 4 MB
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe 3.0 x4 - NVM Express (NVMe)
Display
15.6"
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
141
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Colour Gamut
45% NTSC
Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, 35 ms response rate, 0.17925 mm pixel pitch
Audio & Video
Graphics Processor
AMD Radeon Vega 8
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
78.6 degrees, RGB camera
Sound
Stereo speakers, microphone
High Definition Audio
Input
Keyboard, touchpad
Numeric Keypad
Communications
Wireless
Wireless Controller
Realtek RTL8821CE - M.2 2230
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111H
3-cell lithium polymer
41 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Interfaces Details
HDMI , 2 x USB 3.2 Gen 1 , USB 2.0 , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.7 kg
Sustainability Information
TCO Certified
Bundled Services
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
GM1Y Dell Upgrade from 1Y Collect & Return to 3Y Basic Onsite - extended service agreement In Stock £98.16
Other bundles (4)
GM1Y Dell Slim DW316 USB External DVD Drive In Stock £28.03
GM1Y Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £10.03
GM1Y Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £14.71
GM1Y Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £25.01
