Meet the reliable, small desktop redesigned to fit perfectly on your desk and with your business.
Packed with power: Work throughout your day quickly and conveniently with the latest Intel processors and up to 8GB2 of high-speed RAM options, delivering power and reliable performance.
Stay connected: Quickly transmit important business data with built-in WiFi or a Gigabit Ethernet connection.
A boost in multitasking: Run multiple apps faster and enjoy sharp, high-quality visuals on everything from Excel spreadsheets to video editing with up to 2GB2 of optional discrete graphics.
Plenty of room: Save and access presentations, documents and media without worry of space limitations with up to a 2TB2 HDD.
Built for desk space: The compact form factor design ensures that you save space without sacrificing features or performance.
Uninterrupted performance: The new ventilation system and ultra-fine filter were created to improve airflow, reduce dust, and help keep your system cool.
Easy expansion: Need more performance? You can upgrade the Vostro Small Desktop as needed with expansion slot options to keep up with your business growth.
Packed with power
Work throughout your day quickly and conveniently with the Intel processors and up to 8GB of high-speed RAM options, delivering power and reliable performance. -
Stay connected
Quickly transmit important business data with built-in Wi-Fi or a Gigabit Ethernet connection. -
The compact form factor design ensures that you save space without sacrificing features or performance. -
The ventilation system and ultra-fine filter were created to improve airflow, reduce dust, and help keep your system cool. -
Easy expansion
Need more performance? You can upgrade the Vostro Desktop as needed with expansion slot options to keep up with your business growth. -
More to see
Support multiple displays for higher productivity with VGA and HDMI ports.
- Dell Vostro 3250 - SFF - Core i5 6400 2.7 GHz - 4 GB - HDD 500 GB
- Personal computer - small form factor
- Bundled Services
- 1 Year Dell Collect and Return Service
- Processor
- Intel Core i5 (6th Gen) 6400 / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB L3 Cache
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3L SDRAM - non-ECC
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- Graphics Controller
- Intel HD Graphics 530
- Audio Output
- 5.1 channel surround
- Networking
- GigE, Bluetooth, 802.11b/g/n
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Black
- 29.3 cm x 9.26 cm x 29 cm
- 3.17 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 1 year
- Personal computer
- Bundled Services
- Product Form Factor
- Small form factor
- Black
Processor / Chipset
- CPU
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- L3 Cache - 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer
Card Reader
- Card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse (on selected markets only), keyboard (on selected markets only)
Mouse
- Technology
- Optical
- Wireless LAN Supported
- Wireless NIC
- Dell Wireless 1707
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Bays
- 1 (total) / 0 (free) x external 5.25" , 1 (total) / 0 (free) x internal 2 x 2.5"/3.5" shared
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe x16 - full-height , 1 (total) / 1 (free) x PCIe x1 - full-height , 1 (total) / 0 (free) x M.2 Card
- 4 x USB 2.0 , 2 x USB 3.0 (2 in front) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out/headphones , 1 x audio line-in/microphone , 1 x audio line-in , 1 x VGA , 1 x HDMI
- Pricing Type
- Power supply
- Voltage Required
Operating System / Software
- OS Provided
- Software
- 29.3 cm
- 9.26 cm
- 29 cm
- 3.17 kg
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
