The Dell standard capacity black ink cartridges are the most inexpensive solution for those with a very tight budget.
If you like to print in color then the Dell standard capacity color ink cartridge is the most inexpensive solution.
- Dell - colour (cyan, magenta, yellow) - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Colour (cyan, magenta, yellow)
- Cartridge Features
- Dell Ink Management System
- Compatible with
- Dell V105
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Included Qty
- 1-pack
- Compatible with
- Dell V105
