Efficient charging
The Dell power adapter delivers 65 watts of power, ensuring your devices charge quickly and efficiently. Its external form factor makes it easy to carry and use wherever you go. -
Universal connectivity
Featuring a 24-pin USB-C connector, this power adapter offers versatile compatibility with a wide range of devices. Its single connector design simplifies the charging process, making it an ideal choice for those who value convenience and efficiency.
- Dell - USB-C power adapter - 65 Watt
- USB-C power adapter - external
- Localisation
- United Kingdom
- Input Voltage
- AC
- Power Capacity
- 65 Watt
- Output connectors
- 1 x 24 pin USB-C 65 W
- 1-year warranty
- Localisation
- United Kingdom
- Input Voltage
- AC
- Power Output Connectors Details
- Power Capacity
- 65 Watt
- Cables Included
- Power cable 1 m
- Limited warranty - 1 year
