Conveniently dock any laptop, equipped with USB-C or USB 3.0 ports with the Dell universal dock - D6000. You'll be able to connect up to three 4K displays simultaneously. A single USB-C cable connection allows you to transfer audio, video, data and power - enabling a fast and convenient docking experience. It also eliminates the need for an additional power adapter, keeping your desk neat and tidy.
Conveniently connect any laptop, equipped with USB-C or USB 3.0
Enjoy universal compatibility with a wide range of PC brands and operating systems, supported by DisplayLink technology. Whether you're at your desk or in a shared workspace, you can easily connect to displays, a mouse, keyboard and audio devices from your compatible system of choice. -
Connect up to three 4K displays simultaneously
With plug and play, connecting to the dock is fast and convenient. Plug in a single USB-C cable and transfer audio, video, data and power. Plus, the single cable eliminates the need for an additional power adapter, keeping your workspace clean and clutter-free.
- Dell Universal Dock - D6000 - docking station - USB - GigE
- Product Type
- Docking station
- Docking Interface
- USB
- 7.8 cm x 16.8 cm x 3 cm
- 380 g
- Black
- Networking
- Gigabit Ethernet
- Power
- Power adapter 130 Watt
- Designed For
- Inspiron 3780; Latitude 5320, 5520, 7390 2-in-1, 7400 2-in-1; Vostro 5390, 5391; XPS 13 9310, 13 9380
- Product Type
- Docking station
- 7.8 cm
- 16.8 cm
- 3 cm
- 380 g
- Enclosure Colour
- Black
- Data Link Protocol
- Gigabit Ethernet
- 1 x SuperSpeed USB 3.0 , 1 x USB-C , 1 x display / video - HDMI , 2 x display / video - DisplayPort , 1 x USB host , 3 x SuperSpeed USB 3.0 , 1 x SuperSpeed USB 3.0 with PowerShare , 1 x USB-C with PowerShare , 1 x headphones / speakers , 1 x network
- Cables Included
- 1 x USB-C cable , 1 x USB adapter
- Security Slot Type
- Kensington security slot
- Power Device
- Power adapter
- Power Provided
- 130 Watt
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
- Designed For
- Dell Inspiron 3780 , Dell Latitude 5320, 5520, 7390 2-in-1, 7400 2-in-1 , Dell Vostro 5390, 5391 , Dell XPS 13 9310, 13 9380
