The 4K UHD resolution and a high pixel density of 103 ppi shows your work in striking clarity. Experience smooth color gradation and precision across more shades with a high color depth of 1.07 billion colors.
The height adjustable 42.5-inch 4K monitor lets you tilt, swivel and adjust to your specifications. Align it to a multi-monitor setup for an even wider view. Your display is designed for greater comfort under long work days. It includes a flicker-free screen and ComfortView, a feature that reduces up to 60% of harmful blue light emissions.
More ways to see it all
Picture-by-Picture (PBP) enables a comprehensive view of your work by displaying content from up to four different PCs onto one screen. It also includes five easy-to-use templates. -
Exceptional details
The 4K UHD resolution and a high pixel density of 103ppi shows your work in striking clarity. -
Outstanding color
Experience smooth color gradation and precision across more shades with a high color depth of 1.07 billion colors. -
Fully adaptable
The height adjustable 42.5-inch 4K monitor lets you tilt, swivel and adjust to your specifications. Align it to a multi-monitor setup for an even wider view. -
The space to perform
Save valuable desk space thanks to the small monitor base. -
Easy on the eyes
Your display is designed for greater comfort under long work days. It includes a flicker-free screen and ComfortView, a feature that reduces up to 60% of harmful blue light emissions. -
Charge ahead
USB-C connectivity delivers up to 90 W of power, which is the highest power delivery available in a 42.5" 4K monitor. -
More accessible
Conveniently placed USB ports are located at the side of the monitor for quick connectivity. -
Collaboration made easy
HDMI-CEC enables convenient supportability with key zoom room features, like scheduling operating hours and manual on/off. -
Seamless transitions
The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged. -
The key to convenience
Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster. -
More ways to manage
Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
- Dell UltraSharp U4323QE - LED monitor - 4K - 42.51"
- LED-backlit LCD monitor - 42.51"
- Energy Class
- Class G
- Power Consumption (On mode)
- 52.1 W
- USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.2451 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 1000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% Rec 709, 95% sRGB, 98% DCI-P3
- Input Connectors
- 2xHDMI, 2xDisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
- 96.721 cm x 25.64 cm x 59.52 cm
- 18.55 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 1010 kg carbon emissions
- RoHS, BFR-free, PVC-free
- Bundled Services
- 3-Year Advanced Exchange Service and Premium Panel Exchange
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 42.51"
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2451 mm
- Pixel Per Inch
- 103.6
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Mercury free, arsenic-free glass, Dell ComfortView Plus
- 96.721 cm x 25.64 cm x 59.52 cm - with stand (lowest position)
- 18.55 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 8 Watt
- 2 x HDMI , 2 x DisplayPort 1.4 , USB-C 3.2 Gen 2 upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W) , 3 x USB-C 3.2 Gen 2 upstream (data only) , USB-C 3.2 Gen 2 downstream (power up to 15W) , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , 3 x USB 3.2 Gen 2 downstream , Audio line-out , LAN (RJ-45)
Mechanical
- Tilt Angle
- -5/+10
- Swivel Angle
- 40
- Height Adjustment
- 60 mm
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm
- Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot, retail packaging
- Cables Included
- 1 x USB-C to USB-C cable - 1 m , 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type A to C - 1 m , 1 x HDMI cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- 52.1 W
- Power Consumption SDR (On mode)
- 52.1 kWh/1000h
- Power Consumption (Typical)
- 250 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand (lowest position) - width: 96.721 cm - depth: 25.64 cm - height: 59.52 cm - weight: 18.55 kg , With stand (highest position) - width: 96.721 cm - depth: 25.64 cm - height: 65.52 cm - weight: 18.55 kg , Without stand - width: 96.721 cm - depth: 6.408 cm - height: 56.05 cm - weight: 13.16 kg
- Shipping Weight
- 25.23 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 263
- Manufacturing (kg CO2e)
- 513
- Logistics (kg CO2e)
- 124
- Use (kg CO2e)
- 358
- EOL (kg CO2e)
- 14
- Total Carbon w/o Use Phase (kg CO2e)
- 651
- PAIA Version
- 1.3.2, 2022
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £147.00 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £26.91 |
Dell SB521A Magnetic Sound bar | In Stock | £28.02 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £58.86 |
Dell Thunderbolt Dock WD22TB4 180W | In Stock | £188.18 |
Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US | In Stock | £26.91 |
