Dell UltraSharp U4323QE 43" 3840x2160 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: HVK2WS00 Mfr#: DELL-U4323QE
Diagonal Size: 42.51in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, USB-C, HDMI
Hurry, only 1 left in stock!
£719.04 ex VAT
£862.84 inc VAT
The 4K UHD resolution and a high pixel density of 103 ppi shows your work in striking clarity. Experience smooth color gradation and precision across more shades with a high color depth of 1.07 billion colors.
The height adjustable 42.5-inch 4K monitor lets you tilt, swivel and adjust to your specifications. Align it to a multi-monitor setup for an even wider view. Your display is designed for greater comfort under long work days. It includes a flicker-free screen and ComfortView, a feature that reduces up to 60% of harmful blue light emissions.
  • More ways to see it all
    Picture-by-Picture (PBP) enables a comprehensive view of your work by displaying content from up to four different PCs onto one screen. It also includes five easy-to-use templates.
  • Exceptional details
    The 4K UHD resolution and a high pixel density of 103ppi shows your work in striking clarity.
  • Outstanding color
  • Fully adaptable
  • The space to perform
    Save valuable desk space thanks to the small monitor base.
  • Easy on the eyes
  • Charge ahead
    USB-C connectivity delivers up to 90 W of power, which is the highest power delivery available in a 42.5" 4K monitor.
  • More accessible
    Conveniently placed USB ports are located at the side of the monitor for quick connectivity.
  • Collaboration made easy
    HDMI-CEC enables convenient supportability with key zoom room features, like scheduling operating hours and manual on/off.
  • Seamless transitions
    The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
  • The key to convenience
    Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
  • More ways to manage
    Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
Dell UltraSharp U4323QE - LED monitor - 4K - 42.51"
LED-backlit LCD monitor - 42.51"
Energy Class
Class G
Power Consumption (On mode)
52.1 W
USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 95% sRGB, 98% DCI-P3
Input Connectors
2xHDMI, 2xDisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
96.721 cm x 25.64 cm x 59.52 cm
18.55 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
1010 kg carbon emissions
RoHS, BFR-free, PVC-free
Bundled Services
3-Year Advanced Exchange Service and Premium Panel Exchange
Display Type
Energy Class
Class G
Diagonal Size
42.51"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2451 mm
Pixel Per Inch
103.6
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Mercury free, arsenic-free glass, Dell ComfortView Plus
96.721 cm x 25.64 cm x 59.52 cm - with stand (lowest position)
18.55 kg
Audio
Speakers - stereo
Output Power / Channel
8 Watt
2 x HDMI , 2 x DisplayPort 1.4 , USB-C 3.2 Gen 2 upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W) , 3 x USB-C 3.2 Gen 2 upstream (data only) , USB-C 3.2 Gen 2 downstream (power up to 15W) , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , 3 x USB 3.2 Gen 2 downstream , Audio line-out , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+10
Swivel Angle
40
Height Adjustment
60 mm
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot, retail packaging
1 x USB-C to USB-C cable - 1 m , 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type A to C - 1 m , 1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
52.1 W
52.1 kWh/1000h
Power Consumption (Typical)
250 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Dimensions & Weight Details
With stand (lowest position) - width: 96.721 cm - depth: 25.64 cm - height: 59.52 cm - weight: 18.55 kg , With stand (highest position) - width: 96.721 cm - depth: 25.64 cm - height: 65.52 cm - weight: 18.55 kg , Without stand - width: 96.721 cm - depth: 6.408 cm - height: 56.05 cm - weight: 13.16 kg
Shipping Weight
25.23 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
263
Manufacturing (kg CO2e)
512.5
Logistics (kg CO2e)
124
Use (kg CO2e)
358
EOL (kg CO2e)
14.3
Total Carbon w/o Use Phase (kg CO2e)
652
PAIA Version
1.3.2, 2022
Bundled Services
10 - 80% (non-condensing)
HVK2 Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £144.84
HVK2 Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £34.45
HVK2 Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £59.08
HVK2 Dell Thunderbolt Dock WD22TB4 180W In Stock £170.53
HVK2 Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £33.64
Response Time: 5ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Dell
Price Range Ex VAT: £500 - £750
