Dell UltraSharp U3824DW 38" 3840x1600 5ms HDMI DisplayPort USB-C LED Curved Monitor
Quicklinx: HR4SWS00 Mfr#: DELL-U3824DW
Diagonal Size: 38in
Max Resolution: 3840 x 1600
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, USB-C, HDMI
42 In Stock
£912.73 ex VAT
£1,095.27 inc VAT
Dell UltraSharp 38 Curved USB-C Hub Monitor - U3824DW - 95.25cm (37.5).
  • A different world of productivity
    Productivity has never been so vibrant. Introducing the 37.5? WQHD+ monitor with IPS Black panel technology. The curved screen improves field of view while reducing reflection and eye fatigue to give you a comfortable, immersive experience.
  • Invigorating color
    Admire the extraordinary world of your work through vibrant colors and deep blacks with this monitor that offers IPS Black panel technology with 2000:1 contrast ratio and 100% sRGB, 100% REC.709, 98% DCI P3 and 98% Display P3 color coverage. Experience enhanced eye comfort with ComfortView Plus, an always-on, built-in low blue light screen that reduces potentially harmful blue light emissions without compromising color.
  • Extensive connectivity
    Streamline your workflow with a single cable USB-C that transmits data and video signals while delivering up to 90W of power. Connect to a wide variety of devices with super speed USB-A and USB-C ports and expand connectivity with DP 1.4, HDMI 2.1 ports. Get a fast and stable connection with up to 2.5GbE provided by RJ45 with PXE boot, Mac Address pass-thru and Wake on Lan features. RJ45 lock feature gives you the flexibility to lock the wired Ethernet to a chosen PC while continuing to work from dual PC inputs. Conveniently-located USB-C (up to 15W power) and USB-A quick access ports make it easy to plug in external devices, and built-in dual 9W speakers save you the hassle altogether. Dive right into your project with the built-in Dell power button sync that wakes up and powers on your laptop.
  • Multitask seamlessly
    Connect to two PC sources and Auto KVM (keyboard, video, mouse) will seamlessly switch control to the second connected PC. Use the KVM feature to control both PCs with a single keyboard and mouse. The KVM wizard makes setup a breeze.
  • Built for comfort
    Work comfortably all day long by tilting, swiveling and adjusting your monitor height to however best fits you.
  • Easy management, next-level productivity
    Improved multitasking: Organize your screen with Easy Arrange and save profiles with Easy Arrange Memory.
  • Easy navigation
    Share a single keyboard, mouse and monitor between multiple PCs with USB KVM wizard. Quickly switch between PCs with the quick-access menu or hot keys.
  • Smooth deployment
    Manage your fleet of monitors with features that are automatic, comprehensive and compatible with several tools.
  • Convenient customization
    Quickly access your favorite features and functions with the menu launcher and hot keys.
  • Energy conservation
    Save energy with PowerNap, a feature that dims or puts your monitor to sleep when it's not in use.
Dell UltraSharp U3824DW - LED monitor - curved - 38"
LED-backlit LCD monitor - 38"
Energy Class
Class F
Power Consumption (On mode)
34.8 W
Curved Screen
USB-C hub, KVM ports, USB PD 90 Watt
Panel Type
IPS Black
Aspect Ratio
21:9
Native Resolution
WQHD+ 3840 x 1600 at 60 Hz
Pixel Pitch
0.22908 mm
Brightness
300 cd/m²
Contrast Ratio
2000:1 / 2000:1 (dynamic)
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 98% DCI-P3, 98% P3
Input Connectors
2xHDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
89.426 cm x 25.121 cm x 44.376 cm
13.27 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
Carbon Footprint
906 kg carbon emissions
RoHS, BFR-free, PVC-free
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
38"
Viewable Size
37.52"
Curved Screen
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS Black
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.22908 mm
Pixel Per Inch
110.87
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED edgelight backlight
Mercury free, arsenic-free glass, Dell Easy Arrange, 3-sided bezeless
89.426 cm x 25.121 cm x 44.376 cm - with stand (lowest position)
13.27 kg
Audio
Speakers
Output Power / Channel
9 Watt
DisplayPort 1.4 , 2 x HDMI (HDCP 2.2) , USB-C/DisplayPort 1.4 Alt Mode (power up to 90W) , USB-C 3.2 Gen 2 upstream (data only) , 4 x USB 3.2 Gen 2 downstream , 2 x USB-C 3.2 Gen 2 downstream (power up to 15W) , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out , Network (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB-C cable - 1 m , 1 x USB-C to USB-A cable - 1 m
Input Voltage
34.8 W
35 kWh/1000h
Power Consumption (Typical)
245 Watt
Power Consumption Stand by
0.9 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 89.426 cm - depth: 25.121 cm - height: 44.376 cm - weight: 13.27 kg , With stand (highest position) - width: 89.426 cm - depth: 25.121 cm - height: 56.376 cm - weight: 13.27 kg , Without stand - width: 89.426 cm - depth: 10.235 cm - height: 39.233 cm - weight: 8.79 kg
Shipping Weight
18.98 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
232
Manufacturing (kg CO2e)
486.2
Logistics (kg CO2e)
105
Use (kg CO2e)
302
EOL (kg CO2e)
12.3
Total Carbon w/o Use Phase (kg CO2e)
604
PAIA Version
1.3.2, 2022
Limited warranty - 3 years
10 - 80% (non-condensing)
HR4S Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £35.35
Diagonal Size: 38in
Response Time: 5ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Dell
Price Range Ex VAT: £750 - £1000
