Dell UltraSharp U3223QE 31.5" 3840x2160 8ms DisplayPort HDMI USB-C IPS LED Monitor
Quicklinx: GQKPWS00 Mfr#: DELL-U3223QE
Diagonal Size: 31.5in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, USB-C, HDMI
Hurry, only 2 left in stock!
£650.57 ex VAT
£780.68 inc VAT
Be your most productive on a 31.5" 4K monitor with brilliant color and contrast that features groundbreaking IPS Black technology and a connectivity hub.
Dell UltraSharp U3223QE - LED monitor - 4K - 31.5" - with 3-year Basic Advanced Exchange (CA, US - 3-year Advanced Exchange Service)
LED-backlit LCD monitor - 31.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/955168
Energy Class
Class F
Power Consumption (On mode)
29.4 W
USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.18159 mm
Brightness
400 cd/m²
Contrast Ratio
2000:1 / 2000:1 (dynamic)
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 98% DCI-P3
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
71.261 cm x 23.317 cm x 46.934 cm
10.36 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
880 kg carbon emissions
RoHS, BFR-free, DisplayPort 1.4, HDCP 2.2, PVC-free
3-year warranty
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Display Type
Energy Class
Class F
Energy Class (HDR)
Class E
Diagonal Size
31.5"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.18159 mm
Pixel Per Inch
137.68
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Mercury free, arsenic-free glass, Delta E<2 calibration, 3-sided bezeless
71.261 cm x 23.317 cm x 46.934 cm - with stand (lowest position)
10.36 kg
HDMI (HDCP 2.2) , DisplayPort 1.4 (HDCP 2.2) , DisplayPort output , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W, HDCP 2.2) , USB-C 3.2 Gen 2 upstream (data only) , USB-C 3.2 Gen 2 downstream (power up to 15W) , 4 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C to USB-A cable - 1 m , 1 x USB-C to USB-C cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
29.4 W
29.4 kWh/1000h
Power Consumption HDR (On mode)
26.1 kWh/1000h
Power Consumption (Max)
220 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
Dimensions & Weight Details
With stand (lowest position) - width: 71.261 cm - depth: 23.317 cm - height: 46.934 cm - weight: 10.36 kg , Without stand - width: 71.261 cm - depth: 5.578 cm - height: 41.004 cm
Shipping Weight
14.49 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
210
Manufacturing (kg CO2e)
432.29
Logistics (kg CO2e)
120
Use (kg CO2e)
320
EOL (kg CO2e)
7.55
Total Carbon w/o Use Phase (kg CO2e)
560
PAIA Version
1.3.0, 2021
Premium Panel Exchange
Bundled Services
10 - 80% (non-condensing)
GQKP Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £171.38
GQKP Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.73
GQKP Dell SB521A Magnetic Sound bar In Stock £36.88
GQKP Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £56.48
GQKP Dell Thunderbolt Dock WD22TB4 180W In Stock £170.53
GQKP Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £33.64
Response Time: 5ms
Speakers: None
Interfaces: USB-C
Interfaces: HDMI
Brand: Dell
Price Range Ex VAT: £500 - £750
