Be your most productive on a 31.5" 4K monitor with brilliant color and contrast that features groundbreaking IPS Black technology and a connectivity hub.
 - Dell UltraSharp U3223QE - LED monitor - 4K - 31.5" - with 3-year Basic Advanced Exchange (CA, US - 3-year Advanced Exchange Service)
 - LED-backlit LCD monitor - 31.5"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/955168
- Energy Class
 - Class F
- Power Consumption (On mode)
 - 29.4 W
 - USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
 - 0.18159 mm
- Brightness
 - 400 cd/m²
- Contrast Ratio
 - 2000:1 / 2000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
 - 1.07 billion colours
- Colour Gamut
 - 100% Rec 709, 100% sRGB, 98% DCI-P3
- Input Connectors
 - HDMI, DisplayPort, USB-C
- Built-in Ethernet
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating
- Voltage
 - AC 100-240 V (50/60 Hz)
 - Black
- Dimensions (WxDxH) - with stand (lowest position)
 - 71.261 cm x 23.317 cm x 46.934 cm
 - 10.36 kg
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
 - 880 kg carbon emissions
 - RoHS, BFR-free, DisplayPort 1.4, HDCP 2.2, PVC-free
 - 3-year warranty
- Bundled Services
 - 3 years Basic Hardware Service with Advanced Exchange
- Display Type
- Energy Class
 - Class F
- Energy Class (HDR)
 - Class E
- Diagonal Size
 - 31.5"
- Built-in Devices
- USB Power Delivery
 - 90 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.18159 mm
- Pixel Per Inch
 - 137.68
- Brightness
 - 400 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - LED backlight
 - Mercury free, arsenic-free glass, Delta E<2 calibration, 3-sided bezeless
 - Black
 - 71.261 cm x 23.317 cm x 46.934 cm - with stand (lowest position)
 - 10.36 kg
 - HDMI (HDCP 2.2) , DisplayPort 1.4 (HDCP 2.2) , DisplayPort output , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W, HDCP 2.2) , USB-C 3.2 Gen 2 upstream (data only) , USB-C 3.2 Gen 2 downstream (power up to 15W) , 4 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , LAN (RJ-45)
Mechanical
- Tilt Angle
 - -5/+21
- Swivel Angle
 - 60
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
 - 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C to USB-A cable - 1 m , 1 x USB-C to USB-C cable - 1 m
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 29.4 W
- Power Consumption SDR (On mode)
 - 29.4 kWh/1000h
- Power Consumption HDR (On mode)
 - 26.1 kWh/1000h
- Power Consumption (Max)
 - 220 Watt
- Power Consumption Stand by
 - 0.3 Watt
 - 0.2 Watt
- On / Off Switch
- Dimensions & Weight Details
 - With stand (lowest position) - width: 71.261 cm - depth: 23.317 cm - height: 46.934 cm - weight: 10.36 kg , Without stand - width: 71.261 cm - depth: 5.578 cm - height: 41.004 cm
- Shipping Weight
 - 14.49 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
 - EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
 - 210
- Manufacturing (kg CO2e)
 - 432.29
- Logistics (kg CO2e)
 - 120
- Use (kg CO2e)
 - 320
- EOL (kg CO2e)
 - 7.55
- Total Carbon w/o Use Phase (kg CO2e)
 - 560
- PAIA Version
 - 1.3.0, 2021
 - Premium Panel Exchange
- Bundled Services
 - 0 °C
 - 40 °C
 - 10 - 80% (non-condensing)
                        Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £34.21 |
                        Dell SB521A Magnetic Sound bar | In Stock | £35.62 |
                        Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £56.48 |
                        Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US | In Stock | £35.35 |
