Brilliant color and clarity for your best work. Experience outstanding screen performance on this 31.5" 4K USB-C monitor featuring InfinityEdge and multitasking capabilities.
- Dell UltraSharp U3219Q - LED monitor - 4K - 32"
- LED-backlit LCD monitor - 32"
- Energy Consumption per Year
- 63 kWh
- Power Consumption (On mode)
- 39.8 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.182 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1300:1
- Response Time
- 8 ms (normal); 5 ms (fast)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 95% DCI-P3, 99% Rec 709, 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 71.25 cm x 22 cm x 46.873 cm
- Environmental Standards
- TCO Certified Displays 8
- DisplayPort 1.4, HDCP 2.2
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- OptiPlex 3090; Precision 7560; XPS 13 9310, 13 9380, 15 9510, 15 9570
- Display Type
- 63 kWh
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.182 mm
- Pixel Per Inch
- 140
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1300:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Infinity Edge display, 99% sRGB colour gamut
- Black
- 71.25 cm x 22 cm x 46.873 cm - with stand
- USB-C upstream/DisplayPort Alt Mode with Power Delivery , HDMI (HDCP) , DisplayPort , 2 x USB 3.0 downstream with Battery Charging 1.2 , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 60
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x USB-C cable , 1 x SuperSpeed USB cable - USB Type A to B
- Security Slot Type
- Kensington security slot
- Input Voltage
- 39.8 W
- Power Consumption (Typical)
- 46 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 71.25 cm - depth: 22 cm - height: 46.873 cm , Without stand - width: 71.25 cm - depth: 4.45 cm - height: 41.45 cm
- TCO Certified
- Bundled Services
- Designed For
- Dell OptiPlex 3090 , Dell Precision 7560 , Dell XPS 13 9310, 13 9380, 15 9510, 15 9570
