Dell UltraSharp U3219Q 31.5" 3840x2160 8ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: FFQ8WS00 Mfr#: DELL-U3219Q
Brilliant color and clarity for your best work. Experience outstanding screen performance on this 31.5" 4K USB-C monitor featuring InfinityEdge and multitasking capabilities.
Dell UltraSharp U3219Q - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
Energy Consumption per Year
63 kWh
Power Consumption (On mode)
39.8 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.182 mm
Brightness
400 cd/m²
Contrast Ratio
1300:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
95% DCI-P3, 99% Rec 709, 99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
71.25 cm x 22 cm x 46.873 cm
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
789 kg carbon emissions
DisplayPort 1.4, HDCP 2.2
Bundled Services
3 years Advanced Exchange Service
OptiPlex 3090; Precision 7560; XPS 13 9310, 13 9380, 15 9510, 15 9570
Display Type
63 kWh
Diagonal Size
32"
Viewable Size
31.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.182 mm
Pixel Per Inch
140
Brightness
400 cd/m²
Contrast Ratio
1300:1
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Infinity Edge display, 99% sRGB colour gamut
71.25 cm x 22 cm x 46.873 cm - with stand
USB-C upstream/DisplayPort Alt Mode with Power Delivery , HDMI (HDCP) , DisplayPort , 2 x USB 3.0 downstream with Battery Charging 1.2 , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
150 mm
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x USB-C cable , 1 x SuperSpeed USB cable - USB Type A to B
Security Slot Type
Kensington security slot
Input Voltage
39.8 W
Power Consumption (Typical)
46 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 71.25 cm - depth: 22 cm - height: 46.873 cm , Without stand - width: 71.25 cm - depth: 4.45 cm - height: 41.45 cm
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
122
Manufacturing (kg CO2e)
420.5
Logistics (kg CO2e)
86
Use (kg CO2e)
278
EOL (kg CO2e)
4.94
Total Carbon w/o Use Phase (kg CO2e)
511
PAIA Version
9/5/2018
Bundled Services
Dell OptiPlex 3090 , Dell Precision 7560 , Dell XPS 13 9310, 13 9380, 15 9510, 15 9570
