Dell UltraSharp U2725QE 27" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor
Quicklinx: J7C8WS00 Mfr#: DELL-U2725QE
40 In Stock
£506.90 ex VAT
£608.28 inc VAT
The Dell UltraSharp 27 4K Thunderbolt Hub Monitor U2725QE delivers image quality with a native resolution of 3840 x 2160, providing clear and detailed visuals. This monitor features a 27-inch diagonal size and a bright 450 cd/m2 image brightness, suitable for work tasks and multimedia consumption. With a contrast ratio of 3000:1 and viewing angles of 178 degrees, every detail is visible on the screen.
Equipped with built-in devices such as a KVM switch and USB 3.2 Gen 2 hub, this monitor enhances the workspace by allowing easy connectivity. The monitor supports USB Power Delivery up to 140 W, enabling fast charging for connected devices. Additionally, features like Auto Brightness Control and Low Blue Light technology contribute to comfortable viewing, making it suitable for extended use while reducing eye strain.
Dell UltraSharp U2725QE - LED monitor - 4K - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2166050
Energy Class
Class F
Power Consumption (On mode)
25.4 W
KVM Switch, USB 3.2 Gen 2/USB-C hub, USB PD 140 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 120 Hz
Pixel Pitch
0.1554 mm
Brightness
450 cd/m²
Contrast Ratio
3000:1
HDR Capable
DisplayHDR 600
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB (CIE 1931), 99% DCI-P3 (CIE 1976), 99% P3
Input Connectors
Thunderbolt 4, HDMI, DisplayPort
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (highest position)
61.244 cm x 18.9 cm x 53.568 cm
7.06 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
289 kg carbon emissions
Plug and Play, RoHS, BFR-free, DisplayPort 1.4, HDCP 2.2, PVC-free, TUV Rheinland Eye Comfort Certification (5-star)
Bundled Services
3 years Advanced Exchange Basic Warranty
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
27"
Built-in Devices
USB Power Delivery
140 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163
Brightness
450 cd/m²
Contrast Ratio
3000:1
HDR Certification
DisplayHDR 600
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 120 Hz
Horizontal Refresh Rate
30 - 275 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Picture in picture, ambient light sensor, picture by picture, Auto Brightness Control, LED edgelight system, daisy chain compatible, Dell Easy Arrange, Eye comfort mode, ultra-thin bezel design, Low Blue Light technology, Dell ComfortView Plus, flicker-free panel
61.244 cm x 18.9 cm x 53.568 cm - with stand (highest position)
7.06 kg
HDMI , DisplayPort 1.4 (HDCP 2.2) , DisplayPort output , Thunderbolt 4 upstream/DisplayPort 1.4 (power up to 140W, HDCP2.2) , Thunderbolt 4 downstream (daisy chain, power up to 15W) , USB-C 3.2 Gen 2 upstream , 4 x USB 3.2 Gen 2 downstream (Type A) , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , 2 x USB-C 3.2 Gen 2 downstream , Audio line-out (mini-jack) , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort 1.4 cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type A to C - 1 m , 1 x Thunderbolt 4 cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
25.4 W
25 kWh/1000h
Power Consumption HDR (On mode)
43.5 kWh/1000h
Power Consumption (Typical)
27.5 Watt
Power Consumption (Max)
325 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (highest position) - width: 61.244 cm - depth: 18.9 cm - height: 53.568 cm - weight: 7.06 kg , With stand (lowest position) - width: 61.244 cm - depth: 18.9 cm - height: 38.568 cm - weight: 7.06 kg , Without stand - width: 61.244 cm - depth: 5.56 cm - height: 35.351 cm - weight: 5.22 kg
Shipping Weight
9.73 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
138.48
Logistics (kg CO2e)
18.26
Use (kg CO2e)
124.8
EOL (kg CO2e)
7.09
Bundled Services
10 - 80% (non-condensing)
Brand: Dell
Price Range Ex VAT: £500 - £750
