Dell UltraSharp U2724D - LED monitor - QHD - 27"
Quicklinx: HSQ8WS00 Mfr#: DELL-U2724D
More than 50 In Stock
£267.12 ex VAT
£320.54 inc VAT
Discover the Dell UltraSharp U2724D monitor, designed to meet the needs of professionals and enthusiasts alike. This 27-inch monitor offers a QHD resolution of 2560 x 1440, delivering sharp and detailed visuals across a wide viewing angle. With 100% Rec 709, 100% sRGB, and 98% DCI-P3 color gamut coverage, it provides accurate colors, making it ideal for tasks requiring color precision. The Dell UltraSharp U2724D is not just about visuals; it also features a built-in USB 3.2 Gen 2/USB-C hub and multiple connectivity options, including HDMI and DisplayPort, facilitating a seamless and clutter-free workspace. Ergonomic design is a priority, with extensive display position adjustments such as height, pivot, swivel, and tilt, ensuring comfort during prolonged use. Moreover, its eco-friendly design, featuring arsenic-free glass and a mercury-free LED edgelight system, aligns with sustainability goals, making it a conscientious choice for environmentally aware users.
  • Wide color gamut
    Experience true-to-life colors with the Dell UltraSharp U2724D, featuring 100% Rec 709, 100% sRGB, and 98% DCI-P3 color gamut coverage, making it suitable for professionals in photography and design.
  • Ergonomic design
    Adjust your viewing angle with ease, thanks to the monitor's comprehensive display position adjustments including height, pivot, swivel, and tilt, ensuring comfort during long work sessions.
  • Seamless connectivity
    Equipped with a built-in USB 3.2 Gen 2/USB-C hub and multiple input options including HDMI and DisplayPort, the Dell UltraSharp U2724D ensures a clutter-free workspace with easy connectivity to your devices.
  • High resolution and clarity
    The 27-inch LED-backlit LCD monitor boasts a QHD resolution of 2560 x 1440, providing sharp and detailed visuals, complemented by a high contrast ratio of 2000:1 for deep blacks and bright whites.
  • Eco-friendly design
    Designed with sustainability in mind, the Dell UltraSharp U2724D features arsenic-free glass and a mercury-free LED edgelight system, alongside compliance with BFR-free, PVC-free, and RoHS standards.
LED-backlit LCD monitor - 27"
Energy Class
Class F
Power Consumption (On mode)
23.9 W
Daisy Chaining
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 120 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
2000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 98% DCI-P3, 98% P3
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
61.224 cm x 19.228 cm x 38.558 cm
6.56 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
605 kg carbon emissions
RoHS, TUV Rheinland Low Blue Light Certification, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free, TCO Certified 9.0
Bundled Services
3 years Advanced Exchange Basic Warranty
Display Type
Energy Class
Class F
Diagonal Size
27"
Daisy Chaining
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.97
Brightness
350 cd/m²
Contrast Ratio
2000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 120 Hz
Horizontal Refresh Rate
30 - 178 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, ultra-thin bezel design, Delta E<2 calibration, 3-sided bezeless, 597 x 336 mm active display area
61.224 cm x 19.228 cm x 38.558 cm - with stand (lowest position)
6.56 kg
HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C 3.2 Gen 2 upstream (SuperSpeed USB (10 Gbps)) , USB-C 3.2 Gen 2 downstream (power up to 15W) , 2 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, brightness sensor, cable management ring
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 2 Type A to Type-C cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
23.9 W
24 kWh/1000h
Power Consumption (Typical)
23.9 Watt
Power Consumption (Max)
85 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (highest position) - width: 61.224 cm - depth: 19.228 cm - height: 53.558 cm - weight: 6.56 kg , Without stand - width: 61.224 cm - depth: 5.012 cm - height: 35.251 cm - weight: 4.49 kg
Shipping Weight
9.4 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
149
Manufacturing (kg CO2e)
376
Logistics (kg CO2e)
46
Use (kg CO2e)
177
EOL (kg CO2e)
5
Total Carbon w/o Use Phase (kg CO2e)
428
PAIA Version
1.3.2, 2022
Bundled Services
10 - 80% (non-condensing)
HSQ8 Dell Thunderbolt Dock WD22TB4 180W In Stock £188.18
Brand: Dell
