Dell UltraSharp U2724D - LED monitor - QHD - 27"
Quicklinx: HSQ8WS00 Mfr#: DELL-U2724D
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Interfaces: DisplayPort, HDMI
More than 50 In Stock
£278.61 ex VAT
£334.33 inc VAT
Discover the Dell UltraSharp U2724D monitor, designed to meet the needs of professionals and enthusiasts alike. This 27-inch monitor offers a QHD resolution of 2560 x 1440, delivering sharp and detailed visuals across a wide viewing angle. With 100% Rec 709, 100% sRGB, and 98% DCI-P3 color gamut coverage, it provides accurate colors, making it ideal for tasks requiring color precision. The Dell UltraSharp U2724D is not just about visuals; it also features a built-in USB 3.2 Gen 2/USB-C hub and multiple connectivity options, including HDMI and DisplayPort, facilitating a seamless and clutter-free workspace. Ergonomic design is a priority, with extensive display position adjustments such as height, pivot, swivel, and tilt, ensuring comfort during prolonged use. Moreover, its eco-friendly design, featuring arsenic-free glass and a mercury-free LED edgelight system, aligns with sustainability goals, making it a conscientious choice for environmentally aware users.
  • Wide color gamut
    Experience true-to-life colors with the Dell UltraSharp U2724D, featuring 100% Rec 709, 100% sRGB, and 98% DCI-P3 color gamut coverage, making it suitable for professionals in photography and design.
  • Ergonomic design
    Adjust your viewing angle with ease, thanks to the monitor's comprehensive display position adjustments including height, pivot, swivel, and tilt, ensuring comfort during long work sessions.
  • Seamless connectivity
    Equipped with a built-in USB 3.2 Gen 2/USB-C hub and multiple input options including HDMI and DisplayPort, the Dell UltraSharp U2724D ensures a clutter-free workspace with easy connectivity to your devices.
  • High resolution and clarity
    The 27-inch LED-backlit LCD monitor boasts a QHD resolution of 2560 x 1440, providing sharp and detailed visuals, complemented by a high contrast ratio of 2000:1 for deep blacks and bright whites.
  • Eco-friendly design
    Designed with sustainability in mind, the Dell UltraSharp U2724D features arsenic-free glass and a mercury-free LED edgelight system, alongside compliance with BFR-free, PVC-free, and RoHS standards.
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1591641
Energy Class
Class F
Power Consumption (On mode)
23.9 W
Daisy Chaining
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 120 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
2000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 98% DCI-P3, 98% P3
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
61.224 cm x 19.228 cm x 38.558 cm
6.56 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
605 kg carbon emissions
RoHS, TUV Rheinland Low Blue Light Certification, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free
Bundled Services
3 years Advanced Exchange Basic Warranty
Display Type
Energy Class
Class F
Diagonal Size
27"
Daisy Chaining
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.97
Brightness
350 cd/m²
Contrast Ratio
2000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 120 Hz
Horizontal Refresh Rate
30 - 178 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, ultra-thin bezel design, Delta E<2 calibration, 3-sided bezeless, 597 x 336 mm active display area
61.224 cm x 19.228 cm x 38.558 cm - with stand (lowest position)
6.56 kg
HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C 3.2 Gen 2 upstream (SuperSpeed USB (10 Gbps)) , USB-C 3.2 Gen 2 downstream (power up to 15W) , 2 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, brightness sensor, cable management ring
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 2 Type A to Type-C cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
23.9 W
24 kWh/1000h
Power Consumption (Typical)
23.9 Watt
Power Consumption (Max)
85 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (highest position) - width: 61.224 cm - depth: 19.228 cm - height: 53.558 cm - weight: 6.56 kg , Without stand - width: 61.224 cm - depth: 5.012 cm - height: 35.251 cm - weight: 4.49 kg
Shipping Weight
9.4 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
149
Manufacturing (kg CO2e)
376.03
Logistics (kg CO2e)
46.43
Use (kg CO2e)
176.99
EOL (kg CO2e)
5.41
Total Carbon w/o Use Phase (kg CO2e)
428.01
PAIA Version
1.3.2, 2022
Bundled Services
10 - 80% (non-condensing)
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Brand: Dell
