Be your most productive on a 27 inch monitor with brilliant color and contrast that features the IPS Black technology and a connectivity hub.
Exceptional contrast
Experience incredible color and superior black performance with a contrast ratio of 2000:1 on the 27" 4K monitor with IPS Black technology. -
Enhanced eye comfort
ComfortView Plus - an always-on, built-in low blue light screen - reduces potentially harmful blue light emissions without compromising color. -
True brilliance
See fine details on this 4K monitor and enjoy truer-to-life color with 98% DCI-P3 and VESA DisplayHDR 400. -
Designed with purpose
With a premium platinum finish and an elegant cable management system made to reduce clutter, it's the monitor built to match any workspace. -
Easy to use
Navigate the menu and adjust screen settings with a convenient joystick control. -
Built for comfort
Tilt, swivel, pivot and adjust the height of your monitor so you can work however you're most comfortable. -
Environmental standards
This monitor uses 85% PCR (Post-consumer Recyclable) plastic in the design and meets the latest environmental standards such as ENERGY STAR and TCO Certified Edge, and is EPEAT Gold.
- Dell UltraSharp U2723QE - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/955176
- Energy Class
- Class F
- Power Consumption (On mode)
- 25.9 W
- USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1554 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 2000:1 / 2000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% Rec 709, 100% sRGB, 98% DCI-P3
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- Dimensions (WxDxH) - with stand (lowest position)
- 61.14 cm x 18.5 cm x 38.518 cm
- 6.64 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 815 kg carbon emissions
- RoHS, BFR-free, PVC-free
- 3-year warranty
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange
- Display Type
- Energy Class
- Class F
- Energy Class (HDR)
- Class G
- Diagonal Size
- 27"
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1554 mm
- Pixel Per Inch
- 163.18
- Brightness
- 400 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Mercury free, arsenic-free glass, Delta E<2 calibration, 3-sided bezeless
- Black
- 61.14 cm x 18.5 cm x 38.518 cm - with stand (lowest position)
- 6.64 kg
- HDMI (HDCP 2.2) , DisplayPort 1.4 (HDCP 2.2) , DisplayPort output , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W, HDCP 2.2) , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 4 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , LAN (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 60
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, anti-theft protection
- Cables Included
- 1 x USB-C to USB-C cable - 1 m , 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type A to B
- Security Slot Type
- Kensington security slot
- Input Voltage
- 25.9 W
- Power Consumption SDR (On mode)
- 25.9 kWh/1000h
- Power Consumption HDR (On mode)
- 37.7 kWh/1000h
- Power Consumption (Max)
- 220 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.2 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand (lowest position) - width: 61.14 cm - depth: 18.5 cm - height: 38.518 cm - weight: 6.64 kg , Without stand - width: 61.14 cm - depth: 5.433 cm - height: 35.301 cm - weight: 4.48 kg
- Shipping Weight
- 9.53 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 203
- Manufacturing (kg CO2e)
- 411.27
- Logistics (kg CO2e)
- 85.3
- Use (kg CO2e)
- 313
- EOL (kg CO2e)
- 5.35
- Total Carbon w/o Use Phase (kg CO2e)
- 502
- PAIA Version
- 1.3.0, 2021
- Premium Panel Exchange
- Bundled Services
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £166.38 |
Other bundles (6)
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £140.19 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £34.45 |
Dell SB521A Magnetic Sound bar | In Stock | £39.93 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £56.48 |
Dell Thunderbolt Dock WD22TB4 180W | In Stock | £170.53 |
Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US | In Stock | £33.64 |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H662 051076 Condition: Customer return - item has been used but is in excellent condition |
£292.41 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
