Dell Ultrasharp U2723QE 27" 3840x2160 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: H662WS00 Mfr#: DELL-U2723QE
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: None
Interfaces: USB-C, DisplayPort, HDMI
More than 50 In Stock
£376.74 ex VAT
£452.08 inc VAT
Standard delivery Delivered within 3-5 working days
Be your most productive on a 27 inch monitor with brilliant color and contrast that features the IPS Black technology and a connectivity hub.
  • Exceptional contrast
    Experience incredible color and superior black performance with a contrast ratio of 2000:1 on the 27" 4K monitor with IPS Black technology.
  • Enhanced eye comfort
    ComfortView Plus - an always-on, built-in low blue light screen - reduces potentially harmful blue light emissions without compromising color.
  • True brilliance
    See fine details on this 4K monitor and enjoy truer-to-life color with 98% DCI-P3 and VESA DisplayHDR 400.
  • Designed with purpose
    With a premium platinum finish and an elegant cable management system made to reduce clutter, it's the monitor built to match any workspace.
  • Easy to use
    Navigate the menu and adjust screen settings with a convenient joystick control.
  • Built for comfort
    Tilt, swivel, pivot and adjust the height of your monitor so you can work however you're most comfortable.
  • Environmental standards
    This monitor uses 85% PCR (Post-consumer Recyclable) plastic in the design and meets the latest environmental standards such as ENERGY STAR and TCO Certified Edge, and is EPEAT Gold.
Dell UltraSharp U2723QE - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/955176
Energy Class
Class F
Power Consumption (On mode)
25.9 W
USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
400 cd/m²
Contrast Ratio
2000:1 / 2000:1 (dynamic)
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 98% DCI-P3
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
61.14 cm x 18.5 cm x 38.518 cm
6.64 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
815 kg carbon emissions
RoHS, BFR-free, PVC-free
3-year warranty
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
27"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163.18
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Mercury free, arsenic-free glass, Delta E<2 calibration, 3-sided bezeless
61.14 cm x 18.5 cm x 38.518 cm - with stand (lowest position)
6.64 kg
HDMI (HDCP 2.2) , DisplayPort 1.4 (HDCP 2.2) , DisplayPort output , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W, HDCP 2.2) , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 4 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft protection
1 x USB-C to USB-C cable - 1 m , 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type A to B
Security Slot Type
Kensington security slot
Input Voltage
25.9 W
25.9 kWh/1000h
Power Consumption HDR (On mode)
37.7 kWh/1000h
Power Consumption (Max)
220 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
Dimensions & Weight Details
With stand (lowest position) - width: 61.14 cm - depth: 18.5 cm - height: 38.518 cm - weight: 6.64 kg , Without stand - width: 61.14 cm - depth: 5.433 cm - height: 35.301 cm - weight: 4.48 kg
Shipping Weight
9.53 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
203
Manufacturing (kg CO2e)
411.27
Logistics (kg CO2e)
85.3
Use (kg CO2e)
313
EOL (kg CO2e)
5.35
Total Carbon w/o Use Phase (kg CO2e)
502
PAIA Version
1.3.0, 2021
Premium Panel Exchange
Bundled Services
35 °C
10 - 80% (non-condensing)
Accessories (1)
H662 Dell Dual Monitor Stand - MDS19 In Stock £166.38
Other bundles (6)
H662 Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £140.19
H662 Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £34.45
H662 Dell SB521A Magnetic Sound bar In Stock £39.93
H662 Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £56.48
H662 Dell Thunderbolt Dock WD22TB4 180W In Stock £170.53
H662 Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £33.64
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: H662 051076
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £309.57
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: USB-C
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Dell
Stock Status: Used Stock
