Dell UltraSharp U2722D 27" 2560x1440 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: GBYTWS00 Mfr#: DELL-U2722D
Elevated productivity. Vibrant color. Take your work to new heights with this 27-inch QHD monitor featuring wide color coverage, ComfortView Plus and fast connectivity.
Dell UltraSharp U2722D - LED monitor - QHD - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Power Consumption (On mode)
20 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 95% DCI-P3
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
61.134 cm x 18.5 cm x 38.513 cm
Environmental Standards
TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
569 kg carbon emissions
Plug and Play, RoHS, NFPA 99, TUV Rheinland, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free
3-year warranty
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Latitude 5320, 5520; OptiPlex 3090; Precision 7560
Display Type
Energy Class
Class E
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.78
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Picture by picture, OSD lock, integrated cable management, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Low Blue Light technology, Delta E<2 calibration
61.134 cm x 18.5 cm x 38.513 cm - with stand
HDMI , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 2 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type C to A - 1 m
Security Slot Type
Kensington security slot
Input Voltage
20 W
20 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption (Max)
74 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.134 cm - depth: 18.5 cm - height: 38.513 cm , Without stand - width: 61.134 cm - depth: 4.95 cm - height: 35.201 cm - weight: 4.38 kg
Shipping Weight
9.62 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
105
Manufacturing (kg CO2e)
355
Logistics (kg CO2e)
49
Use (kg CO2e)
161
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
407
PAIA Version
1.2.13, 2021
Premium Panel Guarantee
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 5320, 5520 , Dell OptiPlex 3090 , Dell Precision 7560
Accessories (1)
GBYT Dell Dual Monitor Stand - MDS19 In Stock £166.08
Other bundles (3)
GBYT Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £26.91
GBYT Dell SB521A Magnetic Sound bar In Stock £28.02
GBYT Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £58.86
