Dell UltraSharp U2715H 27" 2560x1440 8ms HDMI DisplayPort IPS LED Monitor
Quicklinx: G4CQWS00 Mfr#: DELL-U2719D
See fine details and true-to-life color on this 27" QHD monitor in an innovative, stylishly thin design.
Dell UltraSharp U2719D - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
23.8 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% Rec 709, 99.9% sRGB, 85% DCI-P3
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
61.2 cm x 18 cm x 39 cm
8.52 kg
United States
Environmental Standards
ENERGY STAR Qualified
RoHS, BFR-free, HDCP 1.4, PVC-free
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Latitude 7400 2-in-1; XPS 13 9380, 15 9570
Display Type
38 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Mercury free, arsenic-free glass, Dell Easy Arrange
61.2 cm x 18 cm x 39 cm - with stand
8.52 kg
DisplayPort (HDCP) , HDMI (HDCP) , DisplayPort output (MST) , 2 x USB 3.0 downstream , 2 x USB 3.0 downstream with Battery Charging 1.2 , USB 3.0 upstream , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
80
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot
1 x DisplayPort cable , 1 x SuperSpeed USB cable
United States
Security Slot Type
Kensington security slot
Input Voltage
23.8 W
Power Consumption (Typical)
30 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 61.2 cm - depth: 18 cm - height: 39 cm - weight: 8.52 kg , Without stand - width: 61.22 cm - depth: 3.9 cm - height: 35.5 cm - weight: 3.92 kg
Sustainability Information
ENERGY STAR Certified
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 7400 2-in-1 , Dell XPS 13 9380, 15 9570
