Enjoy excellent performance, connectivity, picture quality with enhanced clarity on UltraSharp U2713H 27-inch widescreen flat panel monitor from Dell. The dynamic contrast ratio of 2 million: 1 provides to work in razor-sharp clarity and experience smooth, jitter-free moving images. Get extreme screen clarity and rich images with a WQHD 2560 x 1440 at 60 Hz resolution with a color depth of 1.07 billion colors. Additionally, high response time of 6 ms designed to reduce ghosting and deliver razor sharp images. Enjoy exceptional image quality and color conformity with DVI-D (HDCP). You can easily Plug and Play with the four USB connectors. Be assured of reliable office performance and user comfort with the unique combination of energy-conscious and environmentally sound design of U2713H. Thanks to the lower power consumption with LED technology, PowerNap and Dynamic Dimming, you can also see potential cost savings over time!
The U2713H is designed to comply with the energy-efficiency standards, including ENERGY STAR, EPEAT Gold, TCO certified displays and CEL compliant. Additionally, the EPEAT Gold rating on the U2713H helps ensure that your organization stays aligned with the highest environmental standards. With all such impressive features and more, the U2713H is an ideal choice for your smart and modern lifestyle!
- Dell UltraSharp U2713H - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 66 kWh
- Power Consumption (On mode)
- 45 W
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.231 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB, 120% (CIE 1976), 99% Adobe RGB
- Input Connectors
- HDMI, DVI-D, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 63.93 cm x 20.05 cm x 42.34 cm
- Localisation
- United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Display Type
- Energy Class
- Class C
- 66 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.231 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- HDCP, PremierColor technology, stand lock, integrated cable management
- Black
- 63.93 cm x 20.05 cm x 42.34 cm - with stand
- DVI-D (dual link) (HDCP) , 2 x DisplayPort , HDMI , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
- VESA Mounting Interface
- Security lock slot (cable lock sold separately), integrated cable management
- Included Accessories
- Stand, cable tie
- Cables Included
- 1 x USB cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x DVI cable
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 45 W
- Power Consumption (Typical)
- 60 Watt
- On / Off Switch
- No
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 63.93 cm - depth: 20.05 cm - height: 42.34 cm , Without stand - width: 63.93 cm - height: 37.82 cm - weight: 6.3 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
