Dell UltraSharp U2520D 25" 2560x1440 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: G96LWS00 Mfr#: DELL-U2520D
Diagonal Size: 25in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: None
Interfaces: HDMI, USB-C, DisplayPort
£324.59 ex VAT
£389.50 inc VAT
Experience true color reproduction on this 25" QHD monitor a wide color coverage.
  • Exceptional color
    Get wide color coverage with 95% DCI-P3 - which covers approximately 25% more color space than sRGB - for true color reproduction. This monitor also offers 99% sRGB and 99% Rec 709 color coverage.
  • Outstanding color depth
    With an outstanding color depth, excellent peak brightness and a contrast ratio of 1000:1, images are displayed in true-to-life color. Be prepared for better color gradation and precision in more shades on this VESA DisplayHDR 400 monitor.
  • Accurate color, out of the box
    Your monitor is factory calibrated at 99% sRGB to an accuracy of Delta-E less than 2 for accurate colors right from the start.
  • Impactful clarity
    See fine details with QHD (2560 X 1440) resolution with a high pixel density of 117.5 ppi.
  • USB-C connectivity
    Get up to 90W of power delivery (the highest power delivery in its class) via USB-C, so you can keep your laptop battery charged and enjoy uninterrupted productivity. Also, speed up the time it takes to transition from your desk with a single cable that transmits power, data and video - all at once.
  • InfinityEdge design
    Work with an uninterrupted view across multiple screens with this virtually borderless design.
  • Flexibility for all-day comfort
    With the ability to tilt, swivel, pivot and adjust the height of your monitor to fit your needs, you can stay comfortable all day.
Dell UltraSharp U2520D - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/344559
Energy Class
Class F
Power Consumption (On mode)
22 W
USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.8 million colours
Colour Gamut
95% DCI-P3, 99% Rec 709, 99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
56.77 cm x 18.5 cm x 38.29 cm
6.4 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
592 kg carbon emissions
RoHS, BFR-free, PVC-free, Mercury-free
Bundled Services
3 years Advanced Exchange Service
Latitude 5320, 5520; Precision 7560; XPS 13 9310, 15 9510
Display Type
Energy Class
Class F
Energy Class (HDR)
Class E
Diagonal Size
25"
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.216 mm
Pixel Per Inch
117.5
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
LED edgelight system, Delta E<2 calibration, 99% sRGB colour gamut
56.77 cm x 18.5 cm x 38.29 cm - with stand
6.4 kg
DisplayPort 1.4 , DisplayPort output (MST) , HDMI , USB-C (power up to 90W) , 2 x USB 3.0 downstream , USB 3.0 downstream with Battery Charging 1.2 , USB-C downstream , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft protection
1 x USB-C cable , 1 x DisplayPort cable , 1 x USB-C to USB-A cable , 1 x power cable
Input Voltage
22 W
22 kWh/1000h
Power Consumption HDR (On mode)
16.1 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 56.77 cm - depth: 18.5 cm - height: 38.29 cm - weight: 6.4 kg , Without stand - width: 56.77 cm - depth: 4.99 cm - height: 33.21 cm - weight: 4.2 kg
Shipping Weight
8.8 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
102
Manufacturing (kg CO2e)
377.03
Logistics (kg CO2e)
43.3
Use (kg CO2e)
169
EOL (kg CO2e)
2.49
Total Carbon w/o Use Phase (kg CO2e)
423
PAIA Version
1.2.6, 2020
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 13 9310, 15 9510
Accessories (1)
G96L Dell Dual Monitor Stand - MDS19 In Stock £169.04
Other bundles (3)
G96L Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £34.21
G96L Dell SB521A Magnetic Sound bar In Stock £35.62
G96L Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £35.35
Diagonal Size: 25in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: USB-C
Interfaces: DisplayPort
Brand: Dell
