Exceptional color
Get wide color coverage with 95% DCI-P3 - which covers approximately 25% more color space than sRGB - for true color reproduction. This monitor also offers 99% sRGB and 99% Rec 709 color coverage. -
Outstanding color depth
With an outstanding color depth, excellent peak brightness and a contrast ratio of 1000:1, images are displayed in true-to-life color. Be prepared for better color gradation and precision in more shades on this VESA DisplayHDR 400 monitor. -
Accurate color, out of the box
Your monitor is factory calibrated at 99% sRGB to an accuracy of Delta-E less than 2 for accurate colors right from the start. -
Impactful clarity
See fine details with QHD (2560 X 1440) resolution with a high pixel density of 117.5 ppi. -
USB-C connectivity
Get up to 90W of power delivery (the highest power delivery in its class) via USB-C, so you can keep your laptop battery charged and enjoy uninterrupted productivity. Also, speed up the time it takes to transition from your desk with a single cable that transmits power, data and video - all at once. -
InfinityEdge design
Work with an uninterrupted view across multiple screens with this virtually borderless design. -
Flexibility for all-day comfort
With the ability to tilt, swivel, pivot and adjust the height of your monitor to fit your needs, you can stay comfortable all day.
- Dell UltraSharp U2520D - LED monitor - 25"
- LED-backlit LCD monitor - 25"
- Energy Class
- Class F
- Power Consumption (On mode)
- 22 W
- USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.216 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.8 million colours
- Colour Gamut
- 95% DCI-P3, 99% Rec 709, 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 56.77 cm x 18.5 cm x 38.29 cm
- 6.4 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- RoHS, BFR-free, PVC-free, Mercury-free
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- Latitude 5320, 5520; Precision 7560; XPS 13 9310, 15 9510
- Display Type
- Energy Class
- Class F
- Energy Class (HDR)
- Class E
- Diagonal Size
- 25"
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.216 mm
- Pixel Per Inch
- 117.5
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- LED edgelight system, Delta E<2 calibration, 99% sRGB colour gamut
- 56.77 cm x 18.5 cm x 38.29 cm - with stand
- 6.4 kg
- DisplayPort 1.4 , DisplayPort output (MST) , HDMI , USB-C (power up to 90W) , 2 x USB 3.0 downstream , USB 3.0 downstream with Battery Charging 1.2 , USB-C downstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, anti-theft protection
- Cables Included
- 1 x USB-C cable , 1 x DisplayPort cable , 1 x USB-C to USB-A cable , 1 x power cable
- Input Voltage
- 22 W
- Power Consumption SDR (On mode)
- 22 kWh/1000h
- Power Consumption HDR (On mode)
- 16.1 kWh/1000h
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 56.77 cm - depth: 18.5 cm - height: 38.29 cm - weight: 6.4 kg , Without stand - width: 56.77 cm - depth: 4.99 cm - height: 33.21 cm - weight: 4.2 kg
- Shipping Weight
- 8.8 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 13 9310, 15 9510
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £149.14 |
Other bundles (4)
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £163.47 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £33.58 |
Dell SB521A Magnetic Sound bar | In Stock | £35.35 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £45.51 |
