Bring your work to life in vivid color detail, sharp QHD resolution and extensive connectivity for outstanding usability. Superior screen clarity meets complete color precision for a brilliant viewing experience.
Work the way you want. Position your monitor for ultimate comfort with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals.
Made with eco-friendly materials, the U2515H is BFR/PVC-free (excluding external cables) and has arsenic-free glass and a mercury-free LED panel.
A performance to remember
Enjoy 25" of superb screen clarity on a sharp QHD 2560 x 1440 resolution monitor. Plus, you get great color consistency across an ultra-wide 178°/178° viewing angle. Get exceptional color accuracy and consistency right out of the box, with each monitor factory tuned at 99% sRGB with a deltaE <3. Help boost your productivity with a dual or multi-monitor setup and take advantage of the ultra-thin bezel that is ideal for a seamless, virtually borderless viewing between monitors. Easy Arrange lets you choose how you view your custom window layout. -
Designed for your comfort and convenience
Smoothly pivot 90° clockwise or counter-clockwise, placing the thinnest edges side-by-side for an enhanced viewing experience, especially ideal for dual or multi-monitor set up. The U2515H is VESA-compatible, so you can wall mount your monitor. For convenient connections to other devices in your workspace, the U2515H provides two HDMI (MHL) ports, a DisplayPort, a mini-DisplayPort and five USB 3.0 ports. Quickly charge BC1.2 compatible and other USB devices with a USB 3.01 port found on the rear of the monitor that supplies high-speed charging and powering. -
Reliable and eco-efficient
Your Dell UltraSharp 25 monitor - U2515H is designed to be pixel perfect. -
Environmentally-conscious design
Made with eco-friendly materials, the U2515H is BFR/PVC-free (excluding external cables) and has arsenic-free glass and a mercury-free LED panel. Enhanced power management with PowerNap enables the Dell Display Manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
- Dell UltraSharp U2515H - LED monitor - 25"
- LED-backlit LCD monitor - 25"
- Energy Class
- Class B
- Energy Consumption per Year
- 41 kWh
- Power Consumption (On mode)
- 28 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.216 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey), 19 ms (On/Off)
- Colour Support
- 16.8 million colours
- Colour Gamut
- 76% (CIE 1931), 91% (CIE 1976), 99% sRGB
- Input Connectors
- 2xHDMI, 2xMHL, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.9 cm x 20.5 cm x 39.8 cm
- 6.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VESA EDID, DDC/CI, NFPA 99
- Display Type
- Energy Class
- Class B
- 41 kWh
- Diagonal Size
- 25"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.216 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 86 Hz
- Horizontal Refresh Rate
- 30 - 113 kHz
- Video Bandwidth
- 241.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 5000K, 6500K, 7500K, 10000K, 5700K
- Controls & Adjustments
- Brightness, contrast, sharpness, saturation, gamma correction, rotation, input select, colour temperature, hue, aspect control
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- LED edgelight system, stand lock, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, Factory Calibration, High Bit Rate 2 (HBR2), Transition Minimised Differential Signaling (TMDS) technology, backlight dimming control, 99% sRGB colour gamut
- Black
- 56.9 cm x 20.5 cm x 39.8 cm - with stand
- 6.5 kg
- USB 3.0 upstream , 5 x USB 3.0 downstream , DisplayPort , Mini DisplayPort , 2 x MHL / HDMI , DisplayPort output (MST) , Audio line-out
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 115 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 28 W
- Power Consumption (Typical)
- 87 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 56.9 cm - depth: 20.5 cm - height: 39.8 cm - weight: 6.5 kg , Without stand - width: 56.9 cm - depth: 4.64 cm - height: 33.87 cm - weight: 4.4 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
