Dell UltraSharp U2424HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: HZB7WS00 Mfr#: DELL-U2424HE
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: HDMI, DisplayPort, USB-C
£189.84 ex VAT
£227.80 inc VAT
The Dell UltraSharp U2424HE monitor is designed to meet the needs of professionals and enthusiasts alike, offering a blend of performance, comfort, and convenience. With a 24-inch Full HD display, it delivers crisp and vivid visuals that bring your content to life. The monitor's ergonomic design allows for height, pivot, swivel, and tilt adjustments, ensuring you can find the perfect viewing angle for any task. Color accuracy is paramount, with 100% sRGB and BT.709 coverage, making it a suitable choice for designers and photographers who rely on precise color reproduction.
Connectivity is streamlined, thanks to the built-in USB 3.2 Gen 2/USB-C hub, DisplayPort, HDMI, and USB-C interfaces, supporting up to 90 W USB Power Delivery. This not only reduces cable clutter but also simplifies the charging process for compatible devices. Additionally, the monitor is ENERGY STAR certified, highlighting its energy efficiency. With advanced features like Flicker-Free technology and an anti-glare coating, the Dell UltraSharp U2424HE stands out as a versatile and environmentally friendly option for any workspace.
  • Ergonomic design
    With height, pivot, swivel, and tilt adjustments, the Dell UltraSharp U2424HE offers an ergonomic design that ensures comfort and adaptability for any workspace. Its 150 mm height adjustment coupled with a 180-degree rotation angle and a swivel angle of 90 degrees allows for an optimal viewing experience, reducing strain during long work sessions.
  • Exceptional color accuracy
    The monitor boasts 100% sRGB and BT.709 color gamut coverage, along with an 85% DCI-P3, making it a suitable choice for professionals in design and photography. Delta E<2 calibration ensures colors are reproduced with accuracy, providing a vivid and consistent color experience across various projects.
  • Seamless connectivity
    Equipped with a built-in USB 3.2 Gen 2/USB-C hub, DisplayPort, HDMI, and USB-C interfaces, the Dell UltraSharp U2424HE ensures a wide range of connectivity options. It supports up to 90 W USB Power Delivery, allowing for a streamlined workspace by reducing cable clutter and simplifying the charging process for compatible devices.
  • Advanced display features
    Featuring Flicker-Free technology, a 3-sided bezel-less design, and an LED edgelight system, this monitor is designed to enhance viewing comfort while providing a seamless visual experience. The anti-glare 3H Hard Coating minimizes distractions, allowing for better focus on the task at hand.
Dell UltraSharp U2424HE - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Power Consumption (On mode)
14.5 W
Daisy Chaining
USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 120 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
100% BT.709, 100% sRGB, 85% DCI-P3
Input Connectors
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
53.864 cm x 18.175 cm x 36.4 cm
5.91 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
535 kg carbon emissions
RoHS, TUV Rheinland Low Blue Light Certification, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Daisy Chaining
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.53
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 120 Hz
Horizontal Refresh Rate
31 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Delta E<2 calibration, 3-sided bezeless, 527 x 296 mm active display area
53.864 cm x 18.175 cm x 36.4 cm - with stand (lowest position)
5.91 kg
HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C 3.2 Gen 2 upstream (SuperSpeed USB (10 Gbps)) , USB-C downstream (power up to 15W) , 3 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out , USB-C 3.2 Gen 2 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , Network (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, brightness sensor, cable management ring
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 2 Type A to Type-C cable - 1 m , 1 x USB-C 3.2 Gen 2 cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
14.5 W
15 kWh/1000h
Power Consumption (Typical)
13.6 Watt
Power Consumption (Max)
210 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (highest position) - width: 53.864 cm - depth: 18.175 cm - height: 49.653 cm - weight: 5.91 kg , Without stand - width: 53.864 cm - depth: 4.91 cm - height: 31.121 cm - weight: 3.98 kg
Shipping Weight
8.45 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
122
Manufacturing (kg CO2e)
381.12
Logistics (kg CO2e)
40.69
Use (kg CO2e)
108.8
EOL (kg CO2e)
6.99
Total Carbon w/o Use Phase (kg CO2e)
426.2
PAIA Version
1.3.2, 2022
Limited warranty - 3 years
10 - 80% (non-condensing)
Diagonal Size: 24in
Response Time: 5ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: Dell
