Dell UltraSharp U2422HE 24" 1920x1080 5ms HDMI DisplayPort USB-C LED Monitor
Quicklinx: GDW8WS00 Mfr#: DELL-U2422HE
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, DisplayPort, USB-C
£234.87 ex VAT
£281.84 inc VAT
  • Designed with wellness in mind: Optimize eye comfort with ComfortView Plus—an always on, built-in low blue light screen that reduces blue light emissions while delivering excellent color.
  • Consistent, vibrant colors: Get wide color coverage of 100% sRGB, 100% Rec.709 and 85% DCI-P3.
  • In-Plane Switching technology: See consistent color and picture quality across a wide 178/178 degree viewing angle.
  • See more details: Experience superb screen clarity with Full HD at 1920x1080 resolution on this 23.8-inch screen.
  • Seamless view: Expand your view with virtually borderless InfinityEdge. With a four-sided, ultrathin bezel, you can work with a clear, edge-to-edge display. Use the daisy-chain feature for a seamless multi-monitor setup.
  • Boost productivity: Increase your productivity by up to 21% when you use two monitors together. The OSD (Onscreen Menu Display) settings from one monitor can be synchronised across connected monitors for easy multi-monitor setup.
Dell UltraSharp U2422HE - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/414161
Energy Class
Class C
Energy Consumption per Year
50.84 kWh
Power Consumption (On mode)
11.8 W
USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Input Connectors
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
53.76 cm x 17.96 cm x 36.4 cm
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
538 kg carbon emissions
RoHS, NFPA 99, BFR-free, DisplayPort 1.4, PVC-free, TÜV safety certification
3-year warranty
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Latitude 5320, 5520; Precision 7560
Display Type
Energy Class
Class C
50.84 kWh
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.5
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
LED edgelight system, Flicker Free technology, Premium Panel Guarantee, Mercury free, arsenic-free glass, Infinity Edge display, Rec 709 colour gamut, Delta E<2 calibration, Dell ComfortView Plus
53.76 cm x 17.96 cm x 36.4 cm - with stand
HDMI , DisplayPort 1.4 , DisplayPort output (MST) , USB-C 3.2 Gen 2 upstream , USB-C downstream (power up to 15W) , 3 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out , USB-C 3.2 Gen 2 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , Network (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type C to A - 1 m , 1 x USB-C to USB-C cable - 1 m
Input Voltage
11.8 W
11.8 kWh/1000h
Power Consumption (Typical)
11.8 Watt
Power Consumption (Max)
210 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 53.76 cm - depth: 17.96 cm - height: 36.4 cm , Without stand - width: 53.76 cm - depth: 4.85 cm - height: 31.07 cm - weight: 3.96 kg
Shipping Weight
8.3 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
99
Manufacturing (kg CO2e)
362.45
Logistics (kg CO2e)
42.6
Use (kg CO2e)
131
EOL (kg CO2e)
2.67
Total Carbon w/o Use Phase (kg CO2e)
407
PAIA Version
1.2.13, 2021
Bundled Services
Dell Latitude 5320, 5520 , Dell Precision 7560
Accessories (1)
GDW8 Dell Dual Monitor Stand - MDS19 In Stock £166.38
Other bundles (5)
GDW8 Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.60
GDW8 Dell SB521A Magnetic Sound bar In Stock £36.88
GDW8 Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £56.48
GDW8 Dell Thunderbolt Dock WD22TB4 180W In Stock £170.53
GDW8 Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £33.64
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: Dell
