Designed with wellness in mind: Optimize eye comfort with ComfortView Plus—an always on, built-in low blue light screen that reduces blue light emissions while delivering excellent color.
Consistent, vibrant colors: Get wide color coverage of 100% sRGB, 100% Rec.709 and 85% DCI-P3.
In-Plane Switching technology: See consistent color and picture quality across a wide 178/178 degree viewing angle.
See more details: Experience superb screen clarity with Full HD at 1920x1080 resolution on this 23.8-inch screen.
Seamless view: Expand your view with virtually borderless InfinityEdge. With a four-sided, ultrathin bezel, you can work with a clear, edge-to-edge display. Use the daisy-chain feature for a seamless multi-monitor setup.
Boost productivity: Increase your productivity by up to 21% when you use two monitors together. The OSD (Onscreen Menu Display) settings from one monitor can be synchronised across connected monitors for easy multi-monitor setup.
- Dell UltraSharp U2422HE - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/414161
- Energy Class
- Class C
- Energy Consumption per Year
- 50.84 kWh
- Power Consumption (On mode)
- 11.8 W
- USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 53.76 cm x 17.96 cm x 36.4 cm
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 538 kg carbon emissions
- RoHS, NFPA 99, BFR-free, DisplayPort 1.4, PVC-free, TÜV safety certification
- 3-year warranty
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange
- Designed For
- Latitude 5320, 5520; Precision 7560
- Display Type
- Energy Class
- Class C
- 50.84 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 92.5
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- LED edgelight system, Flicker Free technology, Premium Panel Guarantee, Mercury free, arsenic-free glass, Infinity Edge display, Rec 709 colour gamut, Delta E<2 calibration, Dell ComfortView Plus
- 53.76 cm x 17.96 cm x 36.4 cm - with stand
- HDMI , DisplayPort 1.4 , DisplayPort output (MST) , USB-C 3.2 Gen 2 upstream , USB-C downstream (power up to 15W) , 3 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out , USB-C 3.2 Gen 2 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , Network (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type C to A - 1 m , 1 x USB-C to USB-C cable - 1 m
- Input Voltage
- 11.8 W
- Power Consumption SDR (On mode)
- 11.8 kWh/1000h
- Power Consumption (Typical)
- 11.8 Watt
- Power Consumption (Max)
- 210 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 53.76 cm - depth: 17.96 cm - height: 36.4 cm , Without stand - width: 53.76 cm - depth: 4.85 cm - height: 31.07 cm - weight: 3.96 kg
- Shipping Weight
- 8.3 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 99
- Manufacturing (kg CO2e)
- 362.45
- Logistics (kg CO2e)
- 42.6
- Use (kg CO2e)
- 131
- EOL (kg CO2e)
- 2.67
- Total Carbon w/o Use Phase (kg CO2e)
- 407
- PAIA Version
- 1.2.13, 2021
- Premium Panel Guarantee
- Bundled Services
- Designed For
- Dell Latitude 5320, 5520 , Dell Precision 7560
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £166.38 |
Other bundles (6)
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £140.19 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £34.45 |
Dell SB521A Magnetic Sound bar | In Stock | £39.79 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £56.48 |
Dell Thunderbolt Dock WD22TB4 180W | In Stock | £170.53 |
Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US | In Stock | £33.64 |
