Get a stable, wired connection to your network and peripherals on this sleek 23.8" hub monitor with RJ45, USB-C and a host of other ports.
Connect to productivity
Experience outstanding wired connection to your network. With extensive connectivity options like RJ45 and USB-C, your monitor serves as a productivity hub that delivers stable Ethernet and power - all in a clutter-free setup. -
Enhanced manageability
Managing your monitor is easy with MAC Address pass-through, PXE Boot, and Wake-on-LAN conveniently built in. -
Power of USB-C
Charge your connected laptop with up to 65 W of power using USB-C, a single cable solution that transmits power, data and video signals. And with the Always On Power Delivery feature, your laptop will keep charging, even when the monitor is turned off. USB-C also saves up to 72% of workspace setup time, reduces cable clutter and enables quick transitions from your desk. -
Essential screen performance
Experience clarity and detail with Full HD (1920 x 1080) resolution on a 23.8" screen. -
Color consistency comes standard
Your UltraSharp monitor is factory calibrated at 99% sRGB coverage to an accuracy of Delta-E less than 2, for precise hues right out of the box. Plus with 85% coverage of the DCI-P3 color space, you will see images and video in an even wider range of colors. -
Always the best view
See consistent, vibrant colors across a wide viewing angle enabled by In-Plane Switching (IPS) technology. -
Free up valuable desk space
Optimize your workspace with a stylish monitor featuring a thin panel profile, a compact base, and a cable management slot that can hide cable cutter from view. Plus the conveniently placed USB downstream ports (one featuring power charging) gives you easy access to what you need. -
Expand your efficiency
The virtually borderless InfinityEdge design lets you enjoy a seamless view of your content across multiple monitors. And, with dual monitors, you can increase your productivity by up to 21%. -
Adjust to your comfort
Pivot, tilt, swivel and adjust the height of your monitor for a comfortable setup all day long. Their improved design, with the hinge on the riser, makes it easier to adjust while keeping the riser in the same place. -
Easy on the eyes
This TUV Certified monitor has a flicker-free screen with ComfortView, a feature that reduces harmful blue light emissions. It's designed to optimize eye comfort even over an extended period of time.
- Dell UltraSharp U2421E - LED monitor - 24.1"
- LED-backlit LCD monitor - 24.1"
- Energy Class
- Class E
- Power Consumption (On mode)
- 17.2 W
- Daisy Chaining
- USB-C hub, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Environmental Standards
- TCO Certified Displays 8
- DisplayPort 1.4, HDCP 1.4
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange
- Designed For
- Latitude 3410, 3510, 5310, 5310 2-in-1, 5320, 5410, 5411, 5510, 5511, 5520, 7210 2-in-1, 7310, 7410, 9410 2-in-1, 9510; OptiPlex 3080, 5080, 5480, 7080, 7480; Precision 3440, 3550, 3551, 3640, 5550, 5750, 7550, 7560, 7750; XPS 13 7390, 15 7590, 15 9500, 15 9510
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 24.1"
- Daisy Chaining
- Built-in Devices
- USB-C hub
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 94
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 49 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Frame Rate Control (FRC), Flicker Free technology, 6-bit gamma, Dell Easy Arrange, Dell ComfortView Plus
- Black
- DisplayPort 1.4 , HDMI , USB-C 3.2 Gen 1 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , USB-C 3.2 Gen 1 downstream (power up to 15W) , DisplayPort output (MST) , 2 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , Network (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot
- Security Slot Type
- Kensington security slot
- Input Voltage
- 17.2 W
- Power Consumption SDR (On mode)
- 17.2 kWh/1000h
- Included Software
- Dell Display Manager
Sustainability Information
- TCO Certified
- Bundled Services
- Designed For
- Dell Latitude 3410, 3510, 5310, 5310 2-in-1, 5320, 5410, 5411, 5510, 5511, 5520, 7210 2-in-1, 7310, 7410, 9410 2-in-1, 9510 , Dell OptiPlex 3080, 5080, 5480 All In One, 7080, 7480 All In One , Dell Precision 3440 Small Form Factor, 3550, 3551, 3640 Tower, 5550, 5750, 7550, 7560, 7750 , Dell XPS 13 7390, 13 7390 2-in-1, 15 7590, 15 9500, 15 9510
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £127.52 |
Other bundles (4)
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £163.47 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £27.49 |
Dell SB521A Magnetic Sound bar | In Stock | £36.27 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £57.27 |
