The Dell UltraSharp 24 InfinityEdge monitor U2417H takes your view to the edge with less black borders. Multiple adjustability options allow you to tilt, pivot, swivel and adjust the height of the monitor to best fit the way you work.
Optimize your view
Feast your eyes on the thin borders all four sides of a monitor. Dell's InfinityEdge borders, which provide the bezel width and inactive space, create an almost seamless viewing experience. -
Stunning at every angle
Colors remain consistent across an ultrawide viewing angle, guaranteeing a dazzling display no matter how you view it. -
Vividly clear
Immerse yourself in cohesive multi-monitor view with super thin borders and thinbezel width between two displays on all sides. -
Unmatched versatility
Enjoy full adjustability to pivot, tilt, and swivel your monitor to the position and height you desire. And with HDMI, DP, mini-DP, USB 3.0, and audio line-out ports, connecting to all your peripherals at once is both easy and convenient.
- Dell UltraSharp U2417H - without stand - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI (MHL), DisplayPort, Mini DisplayPort
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.76 cm x 4.52 cm x 31.43 cm
- 3.18 kg
- Plug and Play, VESA EDID, DDC/CI, RoHS
- Display Type
- Energy Class
- Class A
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- 6 ms
- Vertical Refresh Rate
- 24 - 75 Hz
- Horizontal Refresh Rate
- 27 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 5000K, 10000K
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- Stand lock, Dell Custom Color, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, arsenic-free glass, Factory Calibration Report, Infinity Edge display, 99% sRGB colour gamut
- Black
- 53.76 cm x 4.52 cm x 31.43 cm - with stand
- 3.18 kg
- MHL / HDMI , DisplayPort output (MST) , DisplayPort , Mini DisplayPort , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) , Audio line-out (mini-jack)
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, 1 USB 3.0 charging port
- Cables Included
- 1 x SuperSpeed USB cable - USB Type A to B - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - miniDisplayPort to DisplayPort - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 68 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
