Dell UltraSharp U2417H 24" 1920 x 1080 8ms HDMI LED-Backlit LCD
Quicklinx: F2C7WS00 Mfr#: U2417H-WOST
The Dell UltraSharp 24 InfinityEdge monitor U2417H takes your view to the edge with less black borders. Multiple adjustability options allow you to tilt, pivot, swivel and adjust the height of the monitor to best fit the way you work.
  • Optimize your view
    Feast your eyes on the thin borders all four sides of a monitor. Dell's InfinityEdge borders, which provide the bezel width and inactive space, create an almost seamless viewing experience.
  • Stunning at every angle
    Colors remain consistent across an ultrawide viewing angle, guaranteeing a dazzling display no matter how you view it.
  • Vividly clear
    Immerse yourself in cohesive multi-monitor view with super thin borders and thinbezel width between two displays on all sides.
  • Unmatched versatility
    Enjoy full adjustability to pivot, tilt, and swivel your monitor to the position and height you desire. And with HDMI, DP, mini-DP, USB 3.0, and audio line-out ports, connecting to all your peripherals at once is both easy and convenient.
Dell UltraSharp U2417H - without stand - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI (MHL), DisplayPort, Mini DisplayPort
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
53.76 cm x 4.52 cm x 31.43 cm
3.18 kg
Plug and Play, VESA EDID, DDC/CI, RoHS
Display Type
Energy Class
Class A
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
6 ms
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
27 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Stand lock, Dell Custom Color, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, arsenic-free glass, Factory Calibration Report, Infinity Edge display, 99% sRGB colour gamut
53.76 cm x 4.52 cm x 31.43 cm - with stand
3.18 kg
MHL / HDMI , DisplayPort output (MST) , DisplayPort , Mini DisplayPort , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) , Audio line-out (mini-jack)
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, 1 USB 3.0 charging port
1 x SuperSpeed USB cable - USB Type A to B - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - miniDisplayPort to DisplayPort - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
68 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
10 - 80% (non-condensing)
