Experience the technology with the Dell UltraSharp U2413 24" high-performance monitor for consistent colors right out of the box. U2413 with PremierColor comes factory color calibrated to support 99% AdobeRGB which enables brilliant and accurate color hues and saturation. Six axis color control enables further user customization, professional color critical work.
Remarkable screen quality
Count on consistent, calibrated hues with PremierColor, WQHD, up to 1920 x 1200 resolution and a 120% color gamut. -
Stunning color precision and performance
U2413 with PremierColor comes factory color calibrated to support 99% AdobeRGB which enables brilliant and accurate color hues and saturation. Six axis color control enables further user customization, professional color critical work. -
Superb user experience
Convenience is at your fingertips with multiple connectivity ports, including USB 3.0, DisplayPort, mini-DisplayPort, DVI-D (HDCP) and HDMI. -
Consistent, accurate hues
It experiences stunning color precision right out of the box with factory-color calibration. -
Industry color standards
Meet professional design standards with 99% AdobeRGB and 100% sRGB at a deltaE of less than 2. -
High color gamut and depth
A 120% color gamut and 1.07 billion colors helps enable smooth gradation of color and razor sharp details. -
Flexible viewing
Adjust the monitor to your most comfortable setting with tilt, swivel, pivot and height adjustability features. -
Power management features
Dim your monitor or put it into sleep mode with dynamic dimming or PowerNap to help save energy.
- Dell UltraSharp U2413 - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class C
- Energy Consumption per Year
- 59 kWh
- Power Consumption (On mode)
- 40 W
- Card reader, USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB, 120% (CIE 1976), 99% Adobe RGB
- Input Connectors
- HDMI, DVI-D, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.6 cm x 20.05 cm x 41.59 cm
- 7.32 kg
- Localisation
- United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 59 kWh
- Diagonal Size
- 24"
- Built-in Devices
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- HDCP, PremierColor technology, PowerNap
- Black
- 55.6 cm x 20.05 cm x 41.59 cm - with stand
- 7.32 kg
- DVI-D (HDCP) , DisplayPort , Mini DisplayPort , HDMI , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
- VESA Mounting Interface
- Security lock slot (cable lock sold separately), integrated cable management
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable , 1 x DisplayPort cable , 1 x USB cable
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 40 W
- Power Consumption (Typical)
- 60 Watt
- On / Off Switch
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 55.6 cm - depth: 20.05 cm - height: 41.59 cm - weight: 7.32 kg , Without stand - width: 55.6 cm - depth: 6.71 cm - height: 36.16 cm - weight: 5.01 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - express exchange - 3 years - response time: next business day
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
