Dell UltraSharp 30" 2560x1600 8ms DP HDMI Monitor
Quicklinx: CBL3WS00 Mfr#: UP3017
Diagonal Size: 30in
Max Resolution: 2560 x 1600
Response Time: 6ms
Interfaces: DisplayPort, HDMI, Mini DisplayPort
More than 50 in stock
£824.74 ex VAT
£989.68 inc VAT
Color-critical performance. 30" monitor with PremierColor that delivers every creative professional their ideal color space. You'll have precise, professional color right out of the box with flexibility to adjust it to your preferences with PremierColor. View and manage applications between two PCs simultaneously with KVM, PBP and PIP features. Or extend to a secondary monitor with a daisy chain for maximum multitasking.
  • Precise color, out of the box
    With a factory calibration report and a Delta-E > 2, you can be confident that your colors will be impressively accurate right from the start.
  • Wide color coverage
    Major industry standards such as AdobeRGB, sRGB, REC709 and DCI-P3 are 99% covered.
  • Exceptional detail
    With 1.07 billion colors, you can see more details in higher clarity, even across an ultra-wide viewing angle.
  • Expanded canvas
    Advanced connectivity (DP-out) allows for simple daisy chain extension into a second screen.
  • View tailored to you
    Easily display content from two PC sources with picture-by-picture and picture-in-picture features. Plus the KVM feature enables you to manage content with a single keyboard and mouse.
  • Stay connected
    A wide range of connectivity ports ensure that you can connect your secondary devices without extra hardware.
  • Work comfortably
    With height-adjustable, tilt, swivel and pivot features, you can collaborate and work with ease.
Dell UltraSharp UP3017 - LED monitor - 30"
LED-backlit LCD monitor - 30"
Energy Class
Class B
Energy Consumption per Year
73 kWh
Power Consumption (On mode)
54 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
2560 x 1600 at 60 Hz
Pixel Pitch
0.251 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey); 6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
68.69 cm x 21.7 cm x 48.23 cm
9.59 kg
Environmental Standards
TCO Certified Displays 8
Plug and Play, RoHS, BFR
3-year warranty
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Display Type
Energy Class
Class B
73 kWh
54 W
Diagonal Size
30"
Viewable Size
30"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.251 mm
Pixel Per Inch
101
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
HDCP, PremierColor technology, 99% Adobe RGB colour gamut, 99% sRGB colour gamut, Flicker Free technology, daisy chain compatible, Energy Gauge, Premium Panel Guarantee, Mercury free, Colour Calibration, arsenic-free glass, Dell ComfortView, Picture-in-Picture, Picture-by-Picture
68.69 cm x 21.7 cm x 48.23 cm - with stand
9.59 kg
DisplayPort (HDCP) , Mini DisplayPort (HDCP) , 2 x HDMI (HDCP) , DisplayPort output (MST) , 2 x USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 3.0 downstream with Battery Charging 1.2 , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, anti-theft protection, Dell Soundbar mounting slots
1 x SuperSpeed USB cable , 1 x Mini DisplayPort-DisplayPort cable
Security Slot Type
Kensington security slot
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 68.69 cm - depth: 21.7 cm - height: 48.23 cm - weight: 9.59 kg , Without stand - width: 68.69 cm - depth: 5.8 cm - height: 44.71 cm - weight: 6.49 kg
TCO Certified
Limited warranty - 3 years
Bundled Services
35 °C
10 - 80% (non-condensing)
Dell UltraSharp 30 Bundle deal on Dell UltraSharp 30" 2560x1600 8ms DP HDMI Monitor
£923.91
CBL3 C2G 2m Mini DisplayPort to DisplayPort Adapter Cable M/M - White In Stock £12.18
CBL3 C2G 2m Mini DisplayPort to DisplayPort Adapter Cable M/M - Black In Stock £6.66
CBL3 C2G 2m Mini DisplayPort Male to Single Link DVI-D Male Adapter Cable - Black In Stock £16.05
CBL3 C2G 15cm Mini DisplayPort Male to DisplayPort Female Adapter Cable - Black In Stock £8.20
CBL3 C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black In Stock £16.28
Diagonal Size: 30in
Response Time: 6ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: Dell
Price Range Ex VAT: 750 - 1000
