Experience superb screen performance on this 23.8" monitor in an innovative, stylish thin design. Color consistency comes standard: your UltraSharp monitor is factory calibrated at 99% sRGB coverage to an accuracy of Delta-E less than 2, for precise hues right out of the box. Plus with 99% Rec709 and 85% DCI-P3 color coverage, you'll see true-to-life colors in video formats.
Always the best view: see consistent, vibrant colors across a wide viewing angle enabled by In-Plane Switching (IPS) technology. With a stylishly thin panel profile (only 6.5mm at its thinnest) and a compact base that's approximately 30% smaller than its predecessor, you can free up valuable desk space. Adjust to your comfort: pivot, tilt, swivel and adjust the height of your monitor for a comfortable setup all day long. Our improved design, with the hinge on the riser, makes it easier to adjust while keeping the riser in the same place.
Impressive screen performance
Experience superb screen clarity with Full HD (1920x1080) resolution on a 23.8" screen. -
Your UltraSharp monitor is factory calibrated at 99% sRGB coverage to an accuracy of Delta-E less than 2, for precise hues right out of the box. Plus with 99% Rec709 and 85% DCI-P3 color coverage, you'll see true-to-life colors in video formats. -
See consistent, vibrant colors across a wide viewing angle enabled by In-Plane Switching (IPS) technology. -
More room to work
With a stylishly thin panel profile (only 6.5mm at its thinnest) and a compact base that's approximately 30% smaller than its predecessor, you can free up valuable desk space. -
Pivot, tilt, swivel and adjust the height of your monitor for a comfortable setup all day long. The improved design, with the hinge on the riser, makes it easier to adjust while keeping the riser in the same place. -
Clean and clutter-free
Focus on your work while hiding away cable clutter with an improved cable management design. -
Expand your efficiency
The virtually borderless design featuring InfinityEdge lets you enjoy a nearly seamless view of your content across multiple monitors. And, with dual monitors, you can increase your productivity by up to 18%3 . -
More ways to multitask
Easily organize multiple applications using predefined templates or a customized template with the Easy Arrange feature on Dell Display Manager software. Plus, you can conveniently tile your applications across a multi-monitor setup. -
Get right to work
With Auto-restore on Dell Display Manager, you can disconnect, reconnect and all of your applications will be in the same position where you left off.
- Dell UltraSharp U2419H - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Consumption per Year
- 21 kWh
- Power Consumption (On mode)
- 12.3 W
- Daisy Chaining
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% Rec 709, 99.9% sRGB, 85% DCI-P3
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 53.85 cm x 16.5 cm x 34.84 cm
- Environmental Standards
- ENERGY STAR Qualified
- Carbon Footprint
- 545 kg carbon emissions
- RoHS, NFPA 99, BFR-free, PVC-free
- Bundled Services
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Designed For
- Latitude 7400 2-in-1; XPS 13 9380, 15 9570
- Display Type
- 21 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Daisy Chaining
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 92.5
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Mercury free, Dell Easy Arrange, arsenic free
- 53.85 cm x 16.5 cm x 34.84 cm - with stand
- DisplayPort (HDCP) , DisplayPort output (MST) , HDMI (HDCP) , 2 x USB 3.0 downstream , 2 x USB 3.0 downstream with Battery Charging 1.2 , USB 3.0 upstream , Audio line-out (mini-jack)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 80
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 12.3 W
- Power Consumption (Typical)
- 17 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 53.85 cm - depth: 3.9 cm - height: 31.37 cm - weight: 3.14 kg , With stand - width: 53.85 cm - depth: 16.5 cm - height: 34.84 cm
Sustainability Information
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 119
- Manufacturing (kg CO2e)
- 379
- Logistics (kg CO2e)
- 50
- Use (kg CO2e)
- 107
- EOL (kg CO2e)
- 3
- Total Carbon w/o Use Phase (kg CO2e)
- 432
- PAIA Version
- 9/5/2018
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 7400 2-in-1 , Dell XPS 13 9380, 15 9570
