Dell UltraSharp 24" 1920 x 1080 5 ms IPS
Quicklinx: HJMXWS00 Mfr#: DELL-U2424H
More than 50 In Stock
£182.94 ex VAT
£219.52 inc VAT
Discover the perfect blend of performance and eco-conscious design with the Dell UltraSharp U2424H monitor. This 24-inch monitor delivers stunning Full HD visuals, thanks to its IPS technology and LED backlighting, ensuring vivid colors and wide viewing angles. With a sleek, 3-sided bezel-less design, it offers an immersive viewing experience and fits seamlessly into any workspace. The Dell UltraSharp U2424H stands out with its comprehensive color coverage, including 100% sRGB and 100% BT.709, making it a great choice for professionals in photography and design. Additionally, its built-in USB 3.2 Gen 2/USB-C hub and multiple connectivity options, including HDMI and DisplayPort, provide the convenience of connecting multiple devices directly to the monitor. The monitor also prioritizes sustainability with its mercury-free and arsenic-free glass, along with a low carbon footprint, making it an environmentally responsible choice. Whether for work or leisure, the Dell UltraSharp U2424H monitor is designed to enhance productivity and provide a superior viewing experience.
  • Wide color gamut
    Experience true-to-life colors with the Dell UltraSharp U2424H's coverage of 100% sRGB, 100% BT.709, and 85% DCI-P3 color gamuts, making it an ideal monitor for professionals in design and photography.
  • Seamless connectivity
    Equipped with a built-in USB 3.2 Gen 2/USB-C hub, the monitor offers versatile connectivity options for a streamlined workspace, including DisplayPort, HDMI, and USB Type-C ports to connect all your devices effortlessly.
  • Ergonomic design
    The 3-sided bezel-less design not only provides a modern look but also maximizes screen real estate, while the VESA interface support allows for easy mounting, ensuring a comfortable viewing experience whether at home or in the office.
Dell UltraSharp U2424H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Power Consumption (On mode)
13.7 W
Daisy Chaining
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 120 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
100% BT.709, 100% sRGB, 85% DCI-P3
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
53.864 cm x 18.175 cm x 36.4 cm
5.38 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
502 kg carbon emissions
RoHS, TUV Rheinland Low Blue Light Certification, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free, TCO Certified 9.0
Bundled Services
3 years Advanced Exchange Basic Warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Daisy Chaining
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.53
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 120 Hz
Horizontal Refresh Rate
31 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Delta E<2 calibration, 3-sided bezeless, 527 x 296 mm active display area
53.864 cm x 18.175 cm x 36.4 cm - with stand (lowest position)
5.38 kg
HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 2 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, brightness sensor, cable management ring
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 2 Type A to Type-C cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
13.7 W
14 kWh/1000h
Power Consumption (Typical)
11.3 Watt
Power Consumption (Max)
72 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (highest position) - width: 53.864 cm - depth: 18.175 cm - height: 49.653 cm - weight: 5.38 kg , Without stand - width: 53.864 cm - depth: 4.91 cm - height: 31.121 cm - weight: 3.52 kg
Shipping Weight
7.92 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Bundled Services
10 - 80% (non-condensing)
HJMX Dell Thunderbolt Dock WD22TB4 180W In Stock £188.18
Brand: Dell
