Dell UltraSharp 24" 1920 x 1080 5 ms IPS
Quicklinx: HJMXWS00 Mfr#: DELL-U2424H
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: DisplayPort, HDMI
£158.70 ex VAT
£190.44 inc VAT
Discover the perfect blend of performance and eco-conscious design with the Dell UltraSharp U2424H monitor. This 24-inch monitor delivers stunning Full HD visuals, thanks to its IPS technology and LED backlighting, ensuring vivid colors and wide viewing angles. With a sleek, 3-sided bezel-less design, it offers an immersive viewing experience and fits seamlessly into any workspace. The Dell UltraSharp U2424H stands out with its comprehensive color coverage, including 100% sRGB and 100% BT.709, making it a great choice for professionals in photography and design. Additionally, its built-in USB 3.2 Gen 2/USB-C hub and multiple connectivity options, including HDMI and DisplayPort, provide the convenience of connecting multiple devices directly to the monitor. The monitor also prioritizes sustainability with its mercury-free and arsenic-free glass, along with a low carbon footprint, making it an environmentally responsible choice. Whether for work or leisure, the Dell UltraSharp U2424H monitor is designed to enhance productivity and provide a superior viewing experience.
  • Wide color gamut
    Experience true-to-life colors with the Dell UltraSharp U2424H's coverage of 100% sRGB, 100% BT.709, and 85% DCI-P3 color gamuts, making it an ideal monitor for professionals in design and photography.
  • Seamless connectivity
    Equipped with a built-in USB 3.2 Gen 2/USB-C hub, the monitor offers versatile connectivity options for a streamlined workspace, including DisplayPort, HDMI, and USB Type-C ports to connect all your devices effortlessly.
  • Ergonomic design
    The 3-sided bezel-less design not only provides a modern look but also maximizes screen real estate, while the VESA interface support allows for easy mounting, ensuring a comfortable viewing experience whether at home or in the office.
Dell UltraSharp U2424H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Power Consumption (On mode)
13.7 W
Daisy Chaining
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 120 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
100% BT.709, 100% sRGB, 85% DCI-P3
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
53.864 cm x 18.175 cm x 36.4 cm
5.38 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
502 kg carbon emissions
RoHS, TUV Rheinland Low Blue Light Certification, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free
Bundled Services
3 years Advanced Exchange Basic Warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Daisy Chaining
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.53
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 120 Hz
Horizontal Refresh Rate
31 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Delta E<2 calibration, 3-sided bezeless, 527 x 296 mm active display area
53.864 cm x 18.175 cm x 36.4 cm - with stand (lowest position)
5.38 kg
HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 2 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, brightness sensor, cable management ring
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 2 Type A to Type-C cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
13.7 W
14 kWh/1000h
Power Consumption (Typical)
11.3 Watt
Power Consumption (Max)
72 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (highest position) - width: 53.864 cm - depth: 18.175 cm - height: 49.653 cm - weight: 5.38 kg , Without stand - width: 53.864 cm - depth: 4.91 cm - height: 31.121 cm - weight: 3.52 kg
Shipping Weight
7.92 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
115
Manufacturing (kg CO2e)
357.65
Logistics (kg CO2e)
37.09
Use (kg CO2e)
103.29
EOL (kg CO2e)
4.35
Total Carbon w/o Use Phase (kg CO2e)
398.71
PAIA Version
1.3.2, 2022
Bundled Services
10 - 80% (non-condensing)
Diagonal Size: 24in
Response Time: 5ms
Interfaces: HDMI
Brand: Dell
