Discover the perfect blend of performance and eco-conscious design with the Dell UltraSharp U2424H monitor. This 24-inch monitor delivers stunning Full HD visuals, thanks to its IPS technology and LED backlighting, ensuring vivid colors and wide viewing angles. With a sleek, 3-sided bezel-less design, it offers an immersive viewing experience and fits seamlessly into any workspace. The Dell UltraSharp U2424H stands out with its comprehensive color coverage, including 100% sRGB and 100% BT.709, making it a great choice for professionals in photography and design. Additionally, its built-in USB 3.2 Gen 2/USB-C hub and multiple connectivity options, including HDMI and DisplayPort, provide the convenience of connecting multiple devices directly to the monitor. The monitor also prioritizes sustainability with its mercury-free and arsenic-free glass, along with a low carbon footprint, making it an environmentally responsible choice. Whether for work or leisure, the Dell UltraSharp U2424H monitor is designed to enhance productivity and provide a superior viewing experience.
Wide color gamut
Experience true-to-life colors with the Dell UltraSharp U2424H's coverage of 100% sRGB, 100% BT.709, and 85% DCI-P3 color gamuts, making it an ideal monitor for professionals in design and photography. -
Seamless connectivity
Equipped with a built-in USB 3.2 Gen 2/USB-C hub, the monitor offers versatile connectivity options for a streamlined workspace, including DisplayPort, HDMI, and USB Type-C ports to connect all your devices effortlessly. -
Ergonomic design
The 3-sided bezel-less design not only provides a modern look but also maximizes screen real estate, while the VESA interface support allows for easy mounting, ensuring a comfortable viewing experience whether at home or in the office.
 - Dell UltraSharp U2424H - LED monitor - Full HD (1080p) - 24"
 - LED-backlit LCD monitor - 24"
- Energy Class
 - Class D
- Power Consumption (On mode)
 - 13.7 W
- Daisy Chaining
 - USB 3.2 Gen 2/USB-C hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 120 Hz
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1
- Response Time
 - 5 ms (fast), 8 ms (normal)
- Colour Support
 - 16.7 million colours
- Colour Gamut
 - 100% BT.709, 100% sRGB, 85% DCI-P3
- Input Connectors
 - HDMI, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating
- Voltage
 - AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
 - 53.864 cm x 18.175 cm x 36.4 cm
 - 5.38 kg
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
 - 502 kg carbon emissions
 - RoHS, TUV Rheinland Low Blue Light Certification, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free
- Bundled Services
 - 3 years Advanced Exchange Basic Warranty
- Display Type
- Energy Class
 - Class D
- Diagonal Size
 - 24"
- Viewable Size
 - 23.8"
- Daisy Chaining
- Built-in Devices
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.2745 mm
- Pixel Per Inch
 - 92.53
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
 - 48 - 120 Hz
- Horizontal Refresh Rate
 - 31 - 135 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - LED backlight
 - LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Delta E<2 calibration, 3-sided bezeless, 527 x 296 mm active display area
 - 53.864 cm x 18.175 cm x 36.4 cm - with stand (lowest position)
 - 5.38 kg
 - HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 2 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack)
Mechanical
- Tilt Angle
 - -5/+21
- Swivel Angle
 - 90
- Rotation Angle
 - 180
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), VESA interface support, brightness sensor, cable management ring
- Cables Included
 - 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 2 Type A to Type-C cable - 1 m
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 13.7 W
- Power Consumption SDR (On mode)
 - 14 kWh/1000h
- Power Consumption (Typical)
 - 11.3 Watt
- Power Consumption (Max)
 - 72 Watt
- Power Consumption Stand by
 - 0.5 Watt
 - 0.3 Watt
- Included Software
 - Dell Display Manager
- Dimensions & Weight Details
 - With stand (highest position) - width: 53.864 cm - depth: 18.175 cm - height: 49.653 cm - weight: 5.38 kg , Without stand - width: 53.864 cm - depth: 4.91 cm - height: 31.121 cm - weight: 3.52 kg
- Shipping Weight
 - 7.92 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
 - EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
 - 115
- Manufacturing (kg CO2e)
 - 357.65
- Logistics (kg CO2e)
 - 37.09
- Use (kg CO2e)
 - 103.29
- EOL (kg CO2e)
 - 4.35
- Total Carbon w/o Use Phase (kg CO2e)
 - 398.71
- PAIA Version
 - 1.3.2, 2022
- Bundled Services
 - 0 °C
 - 40 °C
 - 10 - 80% (non-condensing)
