Dell U3821DW 38" 3840x1600 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: H3XMWS00 Mfr#: DELL-U3821DW
Diagonal Size: 38in
Max Resolution: 3840 x 1600
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: USB-C, HDMI, DisplayPort
£964.02 ex VAT
£1,156.82 inc VAT
Dell UltraSharp 38 Curved USB-C Hub Monitor - U3821DW - 95.25cm (37.5).
  • More screen to captivate you
    See all of your work and multitask like you've always wanted with more onscreen space on this 37.5-inch ultra-wide WQHD+ (3840 x 1600) curved screen. And with a vertical height of 1600 pixels, you can see more and scroll less.
  • View that draws you in
    The 2300R curved screen creates a wider field of view, minimizes reflection and offers near-uniform visual focus, for a comfortable, panoramic, wrap-around view.
  • Consistent, vibrant colors
    Expect consistent color and picture quality across a wide viewing angle, thanks to IPS technology. See true-to-life color with an incredible color depth of 1.07 billion colors and wide color coverage across industry standards, including 95% DCI-P3.
  • Accurate color, out of the box
    Your monitor is factory-calibrated for accurate colors right from the start.
  • All-encompassing sound
    Integrated dual 9W speakers deliver quality sound for an auditory experience that pulls you in even further.
  • Connect to productivity
    With RJ45 and USB-C, your monitor serves as a productivity hub that delivers stable Ethernet and up to 90W of power delivery - all in a clutter-free setup.
  • Extensive connectivity
    Easily connect to a variety of devices with a wide range of connectivity options, including DP1.4, HDMI, and USB-C: a single-cable solution that transmits data and video while delivering up to 90W of power to charge a wide range of laptops. Plus, quick-access USB-C and super speed USB ports conveniently located at the front enable fast connection to peripherals, such as storage devices and mobile phones, with a charging capability of up to 15W (via USB-C).
  • Multitask efficiently
    Connect two PC sources to the monitor - intelligent auto KVM feature detects the second connected PC and seamlessly switches controls over. View content from both PC sources with Picture-by-Picture (PbP) and Picture-in-Picture (PiP). The KVM (keyboard, video, and mouse) feature allows you to control both PCs with a single keyboard and mouse.
  • Beauty meets function
    Crafted with a premium platinum silver finish, this sleek monitor features a streamlined design that runs the cables through the monitor riser for a clutter-free setup. Plus, you can navigate the menu and adjust screen settings with the easy-to-use joystick control.
  • Comfort is key
    Tilt, swivel, and adjust the height of your monitor because you should be comfortable however and wherever you work.
  • Easy on the eyes
    Optimize eye comfort with a flicker-free screen and ComfortView, a feature that reduces harmful blue light emissions.
  • Productive at every level
    Easy Arrange allows you to easily tile multiple applications across one or more screens with 38 pre-set window partitions and the ability to personalize up to five windows, giving you improved multitasking abilities.
  • Seamless transitions
    The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
  • More ways to manage
    Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
  • Key to convenience
    Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
  • Energy conservation
    Save energy when your monitor is not in use with PowerNap, a feature that dims or puts your monitor to sleep when it's not in use.
Dell UltraSharp U3821DW - LED monitor - curved - 38"
LED-backlit LCD monitor - 38"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/388093
Energy Class
Class F
Power Consumption (On mode)
36.5 W
Curved Screen
USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
WQHD+ 3840 x 1600 at 60 Hz
Pixel Pitch
0.22908 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Colour Gamut
95% DCI-P3
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
89.43 cm x 25.12 cm x 44.38 cm
Environmental Standards
TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
802 kg carbon emissions
RoHS, halogen-free, BFR-free, DisplayPort 1.4, PVC-free
Bundled Services
3 years Advanced Exchange Basic Warranty
Latitude 5320, 5520; Precision 7560
Display Type
Energy Class
Class F
Diagonal Size
38"
Viewable Size
37.52"
Curved Screen
Built-in Devices
USB-C hub
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.22908 mm
Pixel Per Inch
110.87
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
95% DCI-P3
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Mercury free, arsenic-free glass, 3-sided bezeless
89.43 cm x 25.12 cm x 44.38 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
9 Watt
DisplayPort 1.4 , 2 x HDMI , USB-C 3.1 Gen 1 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , USB 3.2 Gen 1 upstream (Type B) , 3 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , USB-C downstream (power up to 15W)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot
1 x USB-C to USB-C cable , 1 x HDMI cable , 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to B
Input Voltage
36.5 W
36.5 kWh/1000h
Power Consumption (Typical)
36.7 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 89.43 cm - depth: 25.12 cm - height: 44.38 cm , Without stand - width: 89.43 cm - depth: 10.24 cm - height: 39.23 cm - weight: 8.8 kg
Shipping Weight
19.9 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
125
Manufacturing (kg CO2e)
413.03
Logistics (kg CO2e)
101.05
Use (kg CO2e)
281.5
EOL (kg CO2e)
6.42
Total Carbon w/o Use Phase (kg CO2e)
520.5
PAIA Version
1.2.13, 2021
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 5320, 5520 ¦ Dell Precision 7560
H3XM Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £147.00
H3XM Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £34.45
H3XM Dell SB521A Magnetic Sound bar In Stock £39.93
H3XM Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £56.48
H3XM Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £33.64
Diagonal Size: 38in
Response Time: 5ms
Interfaces: USB-C
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Dell
Price Range Ex VAT: £750 - £1000
